Old 07-27-2009, 01:29 PM   #1
Naterman35
towing with bags?
Im curious if theirs a cetian way to tow a truck with bags both on a car dolly and flat bed. I was told fully aired up is that true?
Naterman35 is offline   Reply With Quote
Old 07-27-2009, 02:41 PM   #2
Shane
Shane's Avatar
Re: towing with bags?
Trailer it the same way a coil spring vehicle is hauled on a trailer ... tie it down by the axles / tires with the bags aired up.
Shane is offline   Reply With Quote
Old 07-27-2009, 04:26 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
When you say "fully aired up" what do you mean? As shane states you should air to ride height or a little higher if clearence is an issue. Do NOT max it out as it will stress your system just as it would if you were driving withh full pressure applied.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-04-2009, 05:22 AM   #4
andrewmp6
A flat bed is always better for anything you need towed.
andrewmp6 is offline   Reply With Quote
Old 08-08-2009, 09:31 PM   #5
Primer70
Superbad
Primer70's Avatar
Have the bagged vehicle at driving height. Keep an eye on it to be sure it don't leak down & make the straps holding it on the flat bed loose. One of my buddies towed his brothers bagged 62 C10 dropped all the way down on his car trailer & he bent the frame on his 96 Yukon at the hitch mounting points on the frame.
Primer70 is offline   Reply With Quote
Old 08-09-2009, 10:58 AM   #6
Shane
Shane's Avatar
leaving the hold down straps loose is a good way to lose 2 vehicles should you encounter a sudden stop.
