Old 07-27-2009, 01:55 PM   #1
rodman91
rodman91's Avatar
water pump question.
What is the PSI on a edelbrock short water pump?
rodman91 is offline   Reply With Quote
Old 07-27-2009, 03:18 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: water pump question.
I am way outa my depth here....but do water pumps work on psi? or is it just volume of water moved by the rotating fins inside?
Sorry I can't be more help.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 07-27-2009, 03:31 PM   #3
mclairmo
I don't think they are rated on pounds per square inch (psi), which is a measurement of pressure. They are rated on volume, such as 30 gallons per hour (gph). In my experience, the Edelbrock pumps are great, but very expensive. I think you can get comparable performance from a lower priced high volume water pump, such as the Procomp or the ones sold by Summit and Jeg's. The most important factor in fluid flow is the pulley ratios, IMO. Make sure to NOT use underdrive pulleys, such as those sold by March. Use a factory set up where that water pump pulley is noticeably smaller than the crank pulley. This will keep the low rpm flow high, which is what you want to keep the engine cool on the street. Run a new high flow thermostat and a clean radiator with a fan shroud and you should be fine.
mclairmo is offline   Reply With Quote
Old 07-27-2009, 04:19 PM   #4
cdowns
cdowns's Avatar
call edelbrocks tech center for info on edelbrock products
