Old 07-27-2009, 04:43 PM   #1
rddaves54
rddaves54's Avatar
fan shroud cover
I saw this fan shroud and was wondering how it attaches.
I have a 72 and mine does not have any thing covering the top of radiator. I put in a 4 row and was wondering did the trucks come with these covers or did you add them later?
rddaves54 is offline   Reply With Quote
Old 07-27-2009, 04:52 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: fan shroud cover
That's off of a 6 cylinder truck. The bolt holes will be in the core support if you choose to run it. It's just a finger guard, not a shroud.
Old 07-27-2009, 04:58 PM   #3
rddaves54
rddaves54's Avatar
Can it be attached on a V8?
Are the holes in the support standard on all trucks so that this guard would fit?
Old 07-27-2009, 07:10 PM   #4
OLEBEATER
OLEBEATER's Avatar
Yes, had one on mine but went to the reg shroud for better cooling.
OLEBEATER is offline   Reply With Quote
Old 07-27-2009, 07:31 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Just run a regular shroud it will work way better.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-27-2009, 08:32 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Old 07-28-2009, 03:33 PM   #7
mclairmo
You need to run a real shroud, not the finger guard. Without a proper shroud that covers the entire core, the fan will not pull air in through the radiator at a stop or at low speed and you will have low speed cooling problems.
mclairmo is offline   Reply With Quote
Old 07-28-2009, 04:04 PM   #8
Longhorn Man
no... you MAY have cooling problems.
I've had 3 trucks that had no 'real shroud' and never had an issue at all. 2 of them were were in texas, and 2 of them here in Ohio. (obviously, one of them I owned in both locations) A stock 350, a cammed out 350, and a gaggle of caddy big blocks (known for overheating) and the only time I ever had an overheading issue was in truck #2 when I snapped a belt, and later when I had a coolant leak. Obviously, a shroud wouldn't have done anything for that, but none the less. None of them ever saw anything past 210, and usually they stayed more like 190 - 200.
Old 07-28-2009, 04:07 PM   #9
Tx Firefighter
I completely agree. I too have run a few of them over the years with no shroud at all, here in Texas, with no overheating issues. Course, Texas is cooler than the other side of the pillow, but our weather does get hot here.
Old 07-28-2009, 05:01 PM   #10
69GMCLonghorn
69GMCLonghorn's Avatar
Yeah, I've been in Springtown in the middle of summer. Talk about a SWEAT FEST! Interesting area, though. I liked it.
And I too agree with Andy. If things are flowing properly and in good shape, it is possible not to boil over without the shroud. it obviously helps things a lot though.
69GMCLonghorn is offline   Reply With Quote
Old 07-28-2009, 05:51 PM   #11
54blackhornet
54blackhornet's Avatar
My 68 GMC custom has a built 292, 30 over. It never runs hot without a shroud or the finger gard in place, It only has a 1 row radator also. I would like to put a shroud on If I could find one. Will a sbc work on a I6 ? I would like to compliment the Texas fireman for all his insight and thanks for the work you do it must be hot being a fireman in Texas at this time of the year !!!!!!!!!!
54blackhornet is offline   Reply With Quote
Old 07-28-2009, 07:51 PM   #12
mclairmo
Wow, sounds like you can get away without a shroud sometimes. However, I would not risk it when the factory used one. I would stick with the factory set up since they spent a lot of time and money to R&D that cooling set up. I would not want to take the chance that on some hot day, the engine overheats and leaves me stranded.
Old 07-29-2009, 10:00 AM   #13
71tahoe
71tahoe's Avatar
You probably have the narrow radiator. The SBC shroud fits the wider v8 radiator.
71tahoe is offline   Reply With Quote
Old 07-29-2009, 12:03 PM   #14
ll____b0t____ll
ll____b0t____ll's Avatar
I agree with Andy as well.
Im just running the gaurd and ive been doing in town driving in 94 % weather.
I have a 180% thermostate and a full sweep temp gauge and what I see is it runs at 180% as long as its moving and creeps up to 200%-210% at a drive up window.
Knowing i was stuck with a gaurd I made sure to get a permacool fan spacer that got the fan as close to Rad as I could.
Maybe the Aluminium Rad helps but also a long waterpump "engines in the back mounting position" I had to get that fan close enough to create draw.
But hey anyone wanting to donate a good shroud to Morgan ide happy to go that way to lol.
ll____b0t____ll is offline   Reply With Quote
