Old 07-27-2009, 06:43 PM   #1
AirMale
AirMale's Avatar
Show me your Hydoboost brake conversion
I've searched and can't find good pics, part #s and plumbing info. Let's see whatcha got?
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 07-28-2009, 11:18 AM   #2
boatpuller
boatpuller's Avatar
Re: Show me your Hydoboost brake conversion
mines not a conversion,but stock system since mine was a factory diesel.i love my brakes.if you search "hydroboost" there should be alot of info and some pics.are you doing an aftermarket ? or factory ?
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-28-2009, 12:22 PM   #3
AirMale
AirMale's Avatar
I was hoping someone here could walk me through a conversion from 81-87. I might drop some cash on a complete kit who knows.
86 SWB 9.0 LITER
Old 07-28-2009, 05:53 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Check out the latest issue of Classic or Custom Classic Trucks. They did the Wilwood 14/13 and hydroboost. It is pretty straight forward you just have to get the hoses and a T in for the power steering along with the proper length rod.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-28-2009, 07:11 PM   #5
East End K5
I have hydroboost on my K35..I tell ya they are some hard brakes to mash down on with your feet, but you make up for it when you fill the bed with 4 yards of fill......just go to a jyard.....you'll see all you need.....i have pics but i'm not advanced enough to scale down the camera pixel size in a speedy manner....
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP
[B]1972 Chevrolet K5 Blazer RIP
1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP
1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP
[B] 1995 Chevrolet Tahoe 2D [B]
East End K5 is offline   Reply With Quote
Old 07-29-2009, 09:41 AM   #6
454HO
I did a hydroboost conversion on my '86. I basically just searched the Autozone and Rock Auto websites for an '86 diesel truck for all the part numbers.
Here is the parts list I generated when I did mine:
1986 CHEVROLET C10 PICKUP 6.2L 379cid V8 DIESEL MFI(C)
Steering : Power Steering Pressure Hose
GATES Part # 357640 {Pressure Line Assembly 16mm Male O-Ring x 18mm Male O-Ring x 49"} Hydroboost To Gear $19.22 $0.00 1 $19.22
GATES Part # 366630 {Pressure Line Assembly 16mm Male O-Ring x 18mm Male O-Ring x 52 1/4"} Pump To Hydroboost $22.79 $0.00 1 $22.79
Steering : Power Steering Return Hose
GATES Part # 362190 {Bulk Power Steering Hose (4-Ft. Length) C.P.E. Return Hose - 3/8" x 48"} Gear To Pump, Cut to Length, 24" Hydroboost To Pump, Cut to Length, 32" $7.79 $0.00 1 $7.79
Brake/Wheel Hub : Hydraulic Hose
ACDELCO Part # 18J295 {replaces 18032006 #18032006} HOSE,FRT BRK DURAST0P; LEFT HAND; 2 WHEEL DRIVE HOSE,FRT BRK DURAST0P; LEFT HAND; OPTIONAL W/DURASTOP
KIT 18032006; 2 WHEEL DRIVE; w/(JD3) or VACUUM PWR BRK SYS(JB5) or (JD5) or VACUUM PWR BRK SYS(JB6) or (JD6) $13.35 $0.00 1 $13.35
ACDELCO Part # 18J2037 {replaces 18J114 #19169840} HOSE,FRT BRK DURAST0P; RIGHT HAND; 2 WHEEL DRIVE HOSE,FRT BRK DURAST0P; RIGHT HAND; OPTIONAL W/DURASTOP KIT 18031825; 2 WHEEL DRIVE; w/(JD3) or (JD5) or (JD6)or VACUUM PWR BRK SYS(JB5) or VACUUM PWR BRK SYS(JB6)$13.36 $0.00 1 $13.36
ACDELCO Part # 18J2119 {replaces 18031765 #19173040}HOSE,RR BRK DURAST0P; 2 WHEEL DRIVE HOSE,RR BRK DURAST0P; (6.2,454); HOSE,RR BRK $11.93 $0.00 1 $11.93
Brake/Wheel Hub : Power Brake Booster
A-1 CARDONE Part # 527248 {[Hydro-Boost] Reman.} w/JD3, JD5 w/Hydro-Boost; GM codes are on the "Service Parts Identification" sticker. $125.79 $55.00 1 $180.79
Brake/Wheel Hub : Master Cylinder
CARDONE SELECT Part # 131863 w/JD3, JD5 w/Hydro-Boost; GM codes are on the "Service Parts Identification" sticker. $33.79 $0.00 1 $33.79
Disclaimers - - The prices reflect what I found online a year or so ago. You may want to double check to make sure these part numbers are accurate before you start buying parts. Also, I ended up using stainless steel brake hoses at the front calipers and the rear frame to axle.
Note this list does not include the power steering pump. The '00 Vortec 7400 engine I put in my truck already had a hydroboost power steering pump on it, so I did not need one. But one problem I had is the 366630 hose I listed above did not work with my pump, so I had to build my own custom hose.
Also, the hydroboost listed above has a six studs to mount it to the firewall. My vacuum booster only had four. So I had to knock out 2 of the studs to bolt it up. I also had to modify the push rod that attaches to the brake pedal. If I recall correctly, the hole in the pushrod was bigger than the pivot stud on the brake pedal.
Another note, I am on my 3rd master cylinder. The first one I bought was a reman. It leaked immediately, so I exchanged it for another under lifetime warranty. The second one lasted about 2 weeks before it started leaking. So I bought a brand new one, it is holding up so far.
- Greg
454HO is offline   Reply With Quote
Old 07-29-2009, 12:28 PM   #7
AirMale
AirMale's Avatar
That's a big help. THANKS FOR ALL THE PART#'S AND INSIGHT. Anytime you want to show off your set-up, I'd love some pics. Thanks again.
86 SWB 9.0 LITER
