Old 07-27-2009, 09:18 PM   #1
threeonthetree
threeonthetree's Avatar
Bedsides ?
i have a wood bed and im going to take the wood out and put steel floor in
i was wondering if you can do this without changing the bedsides?
Can you use wood bedsides with a steel bed?
threeonthetree is offline   Reply With Quote
Old 07-27-2009, 09:32 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Bedsides ?
The only things you will have to change will be the front panel and the crossmembers. The bedsides will work perfectly as will the wheels tubs.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-27-2009, 09:33 PM   #3
SBC
SBC's Avatar
Re: Bedsides ?
i am in the process of doing the opposite, steel to wood. the bedsides can be used with both but u will need to change the front bed panel. an adapter is also sold that can be welded on.
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
SBC is offline   Reply With Quote
Old 07-27-2009, 09:39 PM   #4
BarryB
BarryB's Avatar
Re: Bedsides ?
Yes the bedsides are the same. the front header panel is different and rear cross sill is different but that should be with the steel floor when you get it.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-27-2009, 09:47 PM   #5
threeonthetree
Re: Bedsides ?
awesome thanks for the tips
i already have the front piece.
the crossmembers will have to changed over from the steel bed.
you cant put the steel floor onto the wood beds crossmembers?
