Old 07-27-2009, 09:58 PM   #1
BLOWN73
new wheels...pic's
ok 20x10 all the way around
basic mods
front 1/4 spacer and longer studs
rear 1.25 inch spacer (for look only)
machined the center of the front wheel larger(don't really know if that helped)
machied the rotor where the dust cap is (machied down to the race)
turning problems......none
dust cap used......no
if i would have had the rotor machined down and machined thiner, as i seen someone else do no spacer would have been needed
center cap moded..no
spindel type western chassie 2.5
mod the spindal.....no
looked bad ass.....................................................YES
BLOWN73 is offline   Reply With Quote
Old 07-27-2009, 10:21 PM   #2
menace121978
menace121978's Avatar
Re: new wheels...pic's
very bad @ss! nice job man!!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-28-2009, 09:50 AM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Very cool looking! What size tires are you running?
tvblazer78 is offline   Reply With Quote
Old 07-28-2009, 10:37 AM   #4
jdurant
Just so you know--I once had to machine a rotor/hub down to fit a wheel for a Buick. A lot of material had to be removed. It was a pain. I dreaded ever changing the rotors, because I knew I would have to do it again. Well, the day finally came to change it. I went to the parts store and bought a set of rotors. Stock replacement, just like the other ones.
Come to find out, that brand fit in there just fine. I did all that for nothing the first time--because I didn't check around.
Looks really good though.
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 07-28-2009, 03:32 PM   #5
BLOWN73
i work at a auto shop, i tryed 3 just to be sure, machine shop only charged $20
2453520
2753520
plan to go to
2753520
3053520
Old 07-28-2009, 03:49 PM   #6
jdurant
Cool. When I did mine, I couldn't find a machine shop that would even touch them. But I had a close friend that managed the neighborhood Napa. We actually did it on a brake lathe. We flipped the bit over on a drum lathe and went to town. It took about 3 hrs per rotor. What a PITA!
It's gonna look real good with that fat of a tire on the back.
I don't remember if you've said, but do you plan to change the color?
Joseph
87 Turbo Buick
87 GMC Sierra SWB
Old 07-28-2009, 04:20 PM   #7
BLOWN73
white with candy blue flames outlined in lime green
Old 08-09-2009, 03:16 PM   #8
BGRAFX
Nice blazer and wheels
BGRAFX is offline   Reply With Quote
Old 08-13-2009, 09:22 AM   #9
OARNGESI
OARNGESI's Avatar
Looks really good
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 08-13-2009, 01:33 PM   #10
nlped
nlped's Avatar
Looks good!
When you say your not using a "dust cap" are you talking about the grease cap on the rotor?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-13-2009, 02:07 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Those look good, nice choice!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-13-2009, 08:00 PM   #12
BLOWN73
Originally Posted by nlped View Post
Looks good!
yes
Old 08-13-2009, 08:01 PM   #13
BLOWN73
Looks good!
yes.................
Old 08-14-2009, 09:19 AM   #14
nlped
nlped's Avatar
^^^ What's gonna keep the grease in the rotor when it gets heated up during driving? Won't the grease be "slung" out and the bearing fail?
Carter
