Old 07-27-2009, 11:50 PM   #1
workinprogress67
Common Interest?
i have a few pieces that i cannot find but have seen that i take interest to for my 67.
-solid door glass that eliminates the vent glass
-5x4.75 bolt pattern for 2.5" drop spindles
-a stainless and poly set of cab mount bushings
workinprogress67 is offline   Reply With Quote
Old 07-28-2009, 12:41 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Common Interest?
First, you might want to get this moved to the general section
search "one piece products" or one piece windows. Brother's truck has a set with a tiny triangle in the corner and one piece products is fully w/out any corner piece.
The bolt pattern on the brakes is determined by the rotor...you can use any aftermarket spindle that will work on your year truck/ball joints.
Energy suspension makes poly cab bushings...not sure if it's stainless inserts though, think it's zinc coated...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
