Old 07-27-2009, 11:59 PM   #1
frankyjoet
Unhappy 73gmc350v5.7l
HI, the lower half of the fuse block does not light when using circuit tester. There are four fuses in the bottom half. What can be the problem and is there a fuse for the fuse block? Also is it true with the key on or off some fuses get current? Need help.
thanks in advance
frankyjoe
frankyjoet is offline   Reply With Quote
Old 07-28-2009, 12:50 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: 73gmc350v5.7l
yes there are some fuses that are hot when the ign switch is in the off position. have you tried checking the fuses with the ign switch on and then with the switch off??
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 07-29-2009, 08:38 PM   #3
frankyjoet
Unhappy Re: 73gmc350v5.7l
Yes, found an ign fuse place on the fuse block and with the ign switch on all pos. the trouble tester does not lite. The fuse is a 4amp. At present am using a remote starter to start, also have been troubleshooting the ignition. That's
where i am now. Would appreciate any help.
thanks,
frankyjoet
