Old 07-28-2009, 11:56 AM   #1
Sweet 85 C10
OG
Sweet 85 C10's Avatar
Wheel Offset & BackSpacing 101
Wassup Guys! Was just wondering if it was possible if we can get a topic dedicated to Wheel Offset and BackSpacing. I know its been on alot of peoples minds lately including mine. And I wanted to see if someone can clear up the understanding of Wheel Offset and Back Spacing. Here are a few questions that I have.
1. My current project im doing 22x9.5 Front & 24x10 Rear-->rear backspacing 6.21 & front backspacing is 5.96-->question is will the rear wheels stick out or sit further in with a Ford 9 Inch Rear 58inches long 31 spline?
2. What size rear spacers would I need to make this work?
3. Do I need spacers for the front as well?
These are questions that I need help answering hopefully someone can answer these and give me a clue of a better understanding.
Sweet 85 C10 is offline   Reply With Quote
Old 07-28-2009, 05:14 PM   #2
Sweet 85 C10
OG
Re: Wheel Offset & BackSpacing 101
Anyone wanna chime in anytime!!!
Old 07-28-2009, 10:58 PM   #3
BigShoe24
True Addiction
BigShoe24's Avatar
I believe the 58" width rear-end will pull your wheels in towards the frame, compared with a GM rear. Making your overall width narrower. Is the front all original, i.e. ( A-arms, spindles, crossmember)? I would think the wheel width, offset, would be ok. This all depends on height of suspension, and what type of set-up are you running out back? Stock trailing arms?
RCC
BigShoe24 is offline   Reply With Quote
Old 07-29-2009, 12:28 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Look here for a ton of info:
http://tires.tirerack.com/tires/Backspacing
Also,... what vehicle are you working on? Is the 58" measurement backing plate to backing plate? Or from the wheel mounting surface?
Keith
Convert to disc brakes.
Old 07-29-2009, 07:51 AM   #5
63 & 64 Bowties
and a few others
There's a lot of info out there.
one search
A lot of wheel manufacturers have calculators on their website.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 07-29-2009, 05:42 PM   #6
Sweet 85 C10
OG
Thanks for the response! Im running an SD Raised Cross member up front. Out back is a bag on bar setup. I was just curious if these wheels will stick out or tuck perfectly. Thanks Again guys!
