Old 07-28-2009, 01:15 PM   #1
epashhans
epashhans's Avatar
67 Speedometer and T5 Trans?
I have a T5 trans in my truck I just picked up, and the speedometer isn't hooked up. I was just curious if the previous owner didn't hook it up because it wouldn't work or just didn't do it. Anyone done this before?
I can get a cable to hook up the T5 to a 75 or newer speedo...might have to retro fit something I am thinking...just hate to start ordering stuff before I hav some more info. Thanks!
epashhans is offline   Reply With Quote
Old 07-28-2009, 06:59 PM   #2
epashhans
epashhans's Avatar
Re: 67 Speedometer and T5 Trans?
Nothing huh? Darn...
Old 07-28-2009, 07:03 PM   #3
brak
brak's Avatar
I've got a t5 sitting in my garage, and my cab off my frame...
I'll check tonight if the stock cable on my 72 will work.
EDIT--->
on second thought, i don't know why it wouldn't work, speedo cable connected fine to a 700r4 that came out of an 88 camaro, and they were interchangable with the T5, so reasoning states stock speedo cable should work...
I'll still check anyway
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 07-28-2009, 08:39 PM   #4
sweet70beast
sweet70beast's Avatar
The 92 V8 Camaro T-5 that I'm going to put into my Nova this winter has a speedo torpeedo(?) from a turbo 350 in it. Originally it had a gear driven electronic speed sensor in it, I took it out and the 350's went right in And it turns with the out put shaft so I'm going to use it.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 07-28-2009, 11:26 PM   #5
epashhans
epashhans's Avatar
Thanks guys. I would really appreciate it brak. If so I will pick up a cable of the right length and be done with it. Hopefully that is!
Old 07-31-2009, 10:06 PM   #6
Brad
Out of the carpool lane.
Brad's Avatar
Look in the engine forums for my T-5 write up I did earlier this year.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 07-31-2009, 10:15 PM   #7
Wrenchbender Ret
If the T-5 has an electric sensor instead of gear drive outlet you will have to change the rear houseing to use a cable. There are some converters on the market but they are expensive.
Wrenchbender Ret is offline   Reply With Quote
Old 08-01-2009, 09:36 AM   #8
sweet70beast
Not aways. If the sensor is below the centerline of the output shaft you have one like mine, if is lined up with the centerline you will have to change the housing.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
