Old 07-28-2009, 02:03 PM   #1
koolky
67-72 Addicted
koolky's Avatar
Dana 44 quick question
Im pulling apart my Dana 44 front axel from my 72 chevy 3/4 ton. is the rotor and hub one piece? or two? can i replace the inner axel seals without pulling all the gears out? Thanks
koolky is offline   Reply With Quote
Old 07-28-2009, 02:15 PM   #2
koolky
67-72 Addicted
koolky's Avatar
Re: Dana 44 quick question
Also, is there any diference in piston size between 72 and 73 calipers?
Old 07-28-2009, 03:23 PM   #3
Burt4x4
Burt4x4's Avatar
Yes, the rotor and Hub are one unit.
In order to get the inner axel seals out you have to remove the carrier inside the pumkin, so axels and everything need to come out. This will not mess up your gear alignment because the alignment shims are squeezed onto the diff by the bearings. Once you remove the diff/carrier you can pop out the seals. Use a long broom handel or something solid that you can push into the axel housing from the wheel side to contact the seal, then tap it out.
Clean and reassemble.
I think the calipers are the same 1/2ton & 3/4ton for all D44 but I am guessing on that one.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 07-29-2009, 09:02 AM   #4
jerry moss
Born Psycho
jerry moss's Avatar
the hub and rotor have to be removed from the spindle in one piece but they are really two seperate pieces-#1 hub, #2 rotor and are held together as a unit by the "pound in" wheel studs.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 07-29-2009, 10:30 AM   #5
Burt4x4
Burt4x4's Avatar
True, I guess I was comparing that to the newer types that are two piece when you pullum off the spindel
Old 07-29-2009, 11:10 AM   #6
koolky
67-72 Addicted
koolky's Avatar
Thanks guys. How do I get the rotor off of the hub? press it off? hammer out the studs?
Old 07-29-2009, 02:34 PM   #7
koolky
67-72 Addicted
koolky's Avatar
Could someone send me a picture of dana 44 shock mounts? Both of mine are broken off and i need to fabricate some new ones. or is there some where i can buy replacment ones? thanks again
Old 07-29-2009, 02:35 PM   #8
Burt4x4
Burt4x4's Avatar
Never realy needed to do that but I would guess a shop press would be easier than trying to hammer them out.
.02c
Old 07-29-2009, 02:38 PM   #9
Burt4x4
Burt4x4's Avatar
I don't have the D44 anylonger but I found saome old pics
hope that helps
Old 07-29-2009, 02:50 PM   #10
koolky
67-72 Addicted
koolky's Avatar
Perfect! Thanks guys, very helpfull
