Old 07-28-2009, 03:51 PM   #1
purewhitemp5
painted over SPID....help!
I recently bought a 1968 Chevy LWB Custom from my father in-law and it seems the PO he Bought it from painted over the SPID. I would like to know some history about this truck like : Original paint color combo ( truck was striped and painted a different color ) , original engine ( it has a mid to late 80's 4 bolt 350 in it now ) , what interior combo , it has no interior now , well it has 71-72 door panels , green sun visors , blue set of 67-68 metal door panels where in the bed , red dash and red (majority is red ) , green , white and blue cab interior , black dash pad , no seats , black seat belts. On the exterior it has Custom/30 doors and fenders ( father -in-law installed ), holes for upper and lower trim , studs for trim around the cab ( just below the rear window) , ss trim around the windows ( I have only 1 piece for each window ) , 6 bolt rally wheels , drums all around , it only has power steering , and original cab clearance lights.
Is there anyway I can remove the paint from the SPID to see whats on it , maybe even a glimpse. I would like to get all the codes and info to replace the SPID with a new one.
V.I.N. is : CE148T121986
Thanks in advance.
purewhitemp5 is offline   Reply With Quote
Old 07-28-2009, 03:56 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: painted over SPID....help!
Try some lacquer thinner to see if you can remove the paint. Your best bet might be to find the build sheet that should still be in either the back of the seat or bottom of the seat or both. It will take about 4 sets of hands to get the build sheet out without tearing it to pieces...don't even try. It will have all of you options on it.
Good luck...how about some pictures.
Oooops...just reread your post....NO SEAT!!!!! VIN will tell you some things like I-6 or V-8, 2wd or 4x4, lwb or swb but that is about all.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 07-28-2009, 05:19 PM   #3
purewhitemp5
So far all I have is C : Conventional cab , E : V-8 Gasoline , 1 : 1/2 Ton , 4 : Pick-up , 8 : 1968 , T : Tarrytown (Sleepy Hollow N.Y.)
Old 07-28-2009, 06:48 PM   #4
tim21391
tim21391's Avatar
i wouldnt use lacquer thinner it will take the words off the paper... id use wax and grease remover... sold at local part store
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 07-28-2009, 06:56 PM   #5
danw210
69 K20
I have used starting fluid, weird I know. It doesn't remove the paint but somehow the codes bleed through while the starting fluid is wet. Grab a pencil and paper, it evaporates quickly.
danw210 is offline   Reply With Quote
Old 07-28-2009, 08:41 PM   #6
chipflyer
chipflyer's Avatar
If your door has the plastic cover over the label either lacquer thinner or starting fluid would work fine to remove the paint. If it doesn't have the plastic cover, you probably won't have much luck reading it unless the previous suggestion works. Most of the 68 labels I have seen didn't have the plastic cover though.
Good luck
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 07-28-2009, 08:46 PM   #7
tcb-1
Nothing to see here.....
tcb-1's Avatar
and if you'd like a beautifully reproduced spid, Jeff (chipflyer) IS da man!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 07-28-2009, 11:23 PM   #8
vectorit
What?
vectorit's Avatar
This can be reproduced to look like the original? I didn't know that.
I'd be very interested in this if it's true.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-29-2009, 02:10 AM   #9
1969 GMC
1969 GMC's Avatar
check out the link in chipflyer's sig
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-29-2009, 02:18 AM   #10
BowTieMan
BowTieMan's Avatar
Start taking body panels apart lol chances are some original color is still behind a blind spot that didn't get the new paint color. That's how my truck is with the cowl panel off.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 07-29-2009, 03:02 PM   #11
purewhitemp5
Will try everything everyone suggested thanks. Did custom C-10's come with a limited slip or was that a separate option ?
Old 07-29-2009, 03:48 PM   #12
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
seperat option i would say.
LOW DOUGH is offline   Reply With Quote
Old 07-30-2009, 03:19 PM   #13
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
I spent several hours trying to remove the paint from mine, only to find
that the vin didn't match.
Now I'm going to make an spid to match my build.
Jack_71C10 is offline   Reply With Quote
