Old 01-08-2003, 03:47 PM   #1
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Solenoid/Starter out right?
Well after coming home from work I slept for about 4 hrs and got up and got in truck to go run errands. Well the truck has no click, nothing to attempt to start. Looks like a dead starter. Tried a hammer on solenoid and nothing. I got 10 amps showing on the gauge so I know I have plenty of power. No power drains. Just came home and parked it then came out when truck was ice cold and this happens. So I'm right in thinking starter/solenoid right? I'm thinking a heat shield this time
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 01-08-2003, 03:56 PM   #2
Prerunner1982
Prerunner1982's Avatar
B could be the ignition switch?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-08-2003, 04:00 PM   #3
79BIG10
79BIG10's Avatar
Not sure. what signs would that give? anyway to test?
Old 01-08-2003, 04:47 PM   #4
79BIG10
79BIG10's Avatar
I just jumped the solenoid and it started spinning. So would this be a bad solenoid? When I did it, the solenoid didn't engage to the flywheel just spun.
Old 01-08-2003, 04:47 PM   #5
PHOENIX
Nevermind
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 01-08-2003, 04:48 PM   #6
79BIG10
79BIG10's Avatar
Yes. I jumped the starter with the key on to verify.
Old 01-08-2003, 04:51 PM   #7
79BIG10
79BIG10's Avatar
Don't the new starters from 88+ are mini starters? If so I might upgrade if possible then. Just got to get teh right bolt pattern
Old 01-08-2003, 04:52 PM   #8
Prerunner1982
B, you might just go ahead and pull the starter and take it to get tested.
Jon
Oklahoma Roll Call
Old 01-08-2003, 04:53 PM   #9
79BIG10
79BIG10's Avatar
I'll do that just wanting to see about a new starter mini style and a heat shield Now if the wife would ever make it home
Old 01-08-2003, 10:22 PM   #10
pkbinplano
pkbinplano
pkbinplano's Avatar
Pull the starter and jump it with jumper cables to see if it spins.
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 01-09-2003, 04:40 AM   #11
79BIG10
79BIG10's Avatar
Well it spins after taking it to get tested. Looks like either I'm wire chasing or ignition replacing. Hope just a loose wire. I'll keep you posted.
Old 01-09-2003, 11:19 AM   #12
arveetek
Ultimate Diesel Dude
arveetek's Avatar
B, there is a fusible link in the wiring down by the starter. Take a test light, and probe the wire going to the start terminal on the solenoid while someone else turns the key to start. You should have power. If not, don't forget about the neutral safety switch. Wiggle the gearshift and see what happens. Otherwise, start checking the wire going into the wire loom above the starter. The fusible link shouldn't be too far away from the starter.
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
Old 01-09-2003, 10:13 PM   #13
Prerunner1982
i forgot about the park nuetral saftey switch, try starting it in N?
Jon
Oklahoma Roll Call
Old 01-10-2003, 02:42 AM   #14
79BIG10
79BIG10's Avatar
Well it was a $.22 fix. The smaller nut came off and broke the wire. I didn't see it before when taking it off. Replaced the nuts (double nutted this time ) and fixed the wire. Starter tested out perfect. Replaced the starter back and fired right off. Now if everything was this cheap and easy to fix.
Old 01-10-2003, 09:02 AM   #15
swervin ervin
You get what you pay for
swervin ervin's Avatar
I love the cheap fixes. Trouble is, most of the time they're not any.
Glad to hear you didn't have to redesign the world to get it fixed.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 01-10-2003, 11:32 AM   #16
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
So you got a Double nut......hee hee
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 01-10-2003, 04:53 PM   #17
79BIG10
79BIG10's Avatar
Yeah better than the only 1 I have now and those work LOL
