Old 07-28-2009, 10:35 PM   #1
scoyote
scoyote's Avatar
Horn, cowl bolts, Flex-a-lite fan....and more questions
OK....getting down to the stuff we cannot remember ;-)
1972 Blazer.....almost...
1) Where does the stock horn go? I took lots of pictures before we tore it down but I can't find one showing location and I browsed quite a few builds on the site and didn't see one so I gave up and figured I'd do it the easy way.
2) Does the cowl bolt down (besides the ends) does it bolt down where the hood/cowl gasket is or is that push pins? And if it is bolts...anyone know what size or where I can get a "kit"? LMC doesn't have them.
3) I want dual electric flex-a-lite fans with thermostat controls. I have these on my Ford and I love them.....anyone else used them on a stock blazer radiator? If so...what size? Flex-a-lite doesn't list a 1972 blazer and I don't have the radiator back from the shop yet.
4) Radiator overflow ideas? Besides the stock big ugly overflow tank, anyone have something that is pretty cool looking and fully functional? I don't really like the look of the stock one.
4) Besides $250 plug wires from MSD for my HEI distributor.....what is a good and capable alternate plug wire? I don't want $40 wires on that stroker but I didn't want to spend $250 either....anyone have a good alternate?
5) Antenna......should have plugged the hole and bought a windshield with it built in but it's beyond that now and I need an antenna. So.....besides stock repro.....????
Some pretty simple and stupid questions for most of you guys but I've been searching the internet, LMC, Truck and Car Shop, GMC Pauls (hard website to find anything) and I'm out of ideas and places to look.
Any help?
1972 Blazer - Bronco Orange - In the werks
http://67-72chevytrucks.com/vboard/s...d.php?t=323444
1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more....
1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-)
2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer.
scoyote is offline   Reply With Quote
Old 07-29-2009, 12:34 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Horn, cowl bolts, Flex-a-lite fan....and more questions
1) Horns are located drivers side on the core support, couple welded nuts on the core support. Right next to the relays
3) Just finished reading a good 4x4 project thread by Rackman, he used a flexalite kit I think, looked really nice
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-29-2009, 07:03 AM   #3
JMac11
JMac11's Avatar
The MSD Blue wires run about 100 Bucks and have a lifetime warranty, as far as that goes. I bracket raced a big block for 10 years with a free set I won. As long as you don't cook them they are great, a little hard to get off the plugs though.
JMac11 is offline   Reply With Quote
Old 07-29-2009, 09:51 AM   #4
RustyParts
RustyParts's Avatar
Here's the cowl screws.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 07-29-2009, 10:17 AM   #5
Burt4x4
Burt4x4's Avatar
I run the dual 13.5" Flex-a-lite fan/shroud, works awesome...well the thermo didn't act like I wanted it to so I manually turn it on/off but other than that it keeps my built 454 nice and cool. I did install a 4cor rad too, requires longer mount brackets I bought from one of the catalogs.
here is the link:
http://www.flex-a-lite.com/auto/html...-electric.html
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 07-29-2009, 12:58 PM   #6
scoyote
scoyote's Avatar
Cool....thanks for the replies, links and help.
It's coming together!
Burt 4x4 is that a dual battery setup you are running?
Old 07-29-2009, 05:51 PM   #7
Burt4x4
Burt4x4's Avatar
Yes, I got a driver side batt box from some dude on the internet years ago. I don't remember what he told me he pulled it out of but is was 67-72. It looks identical to the pass side just reverse and bolted right up to my rad support
Old 07-29-2009, 05:57 PM   #8
Burt4x4
Burt4x4's Avatar
Here is another shot..
