07-28-2009, 11:25 PM | #1 |
tailgate skins
What exactly is a tailgate skin and how does it work? is it just a piece of sheetmetal that is welded over the existing tailgate?
Anyways, I like the look of this one and I'm wondering how I would go about installing it http://sirmichaels.com/display_part/120.php |
07-28-2009, 11:31 PM | #2 |
6.0 powered square
Re: tailgate skins
A tail gate skin shave the dimple in the tail gate and then a handle flip kit is needed or you can design your own, the piece you like covers just the dimple and it is welded in and body work is done to make it look good
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-28-2009, 11:46 PM | #3 |
78 Big10 454
Re: tailgate skins
I've got a full skin on my truck with the handle flip kit. Be advised, the tailgate is pretty heavy and I'm not as young (or strong) as I used to be.
07-29-2009, 12:00 AM | #4 |
Badass
Re: tailgate skins
another Q?
do your tailgate move up and down when its closed and u grab it from the bottom?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
07-29-2009, 01:48 AM | #5 |
78 Big10 454
Re: tailgate skins
There's no change in the operation of the tailgate with the full skin installed. It operates just like the factory tailgate, except I have to reach into the bed to unlatch it because of the handle flip kit.
07-29-2009, 11:55 PM | #6 |
Re: tailgate skins
damn that looks really good, I wonder if I should do that..
Adam M STX Designs Motorcycles | Choppers | Hotrods |
07-30-2009, 01:21 AM | #7 |
Re: tailgate skins
My tailgate is incredibly heavy. Its atleast twice as heavy as it was before. Worth every pound, unless you run it down the track, it'll probably set you back a whole 10sec lol
07-30-2009, 05:30 AM | #8 |
BAD BOW-Silverado XST
Re: tailgate skins
I have a louvered skin and tailgate from www.mar-k.com
10-27-2009, 11:07 PM | #9 |
Re: tailgate skins
Are these tailgate skins wobbly in the middle. Just wondering because they are only welded on the sides and top and bottom. Or is the guage metal thick enough it wont cause a concern.
Mexican |
10-27-2009, 11:09 PM | #10 |
Re: tailgate skins
Mar-k stuff is thick. It will not wobble in the middle. I had a plate welded behind the louvers. The plate reinforces the middle section. Plus, water it kept out between the tailgate and skin.
10-27-2009, 11:12 PM | #11 |
Re: tailgate skins
ok, thanks.
Mexican |
10-27-2009, 11:50 PM | #12 |
I have car A.D.D.
Re: tailgate skins
The MAR-K piece covers the whole gate, and it is cheaper, and they are a site vendor. If you are going to get one, I strongly recommend theirs. On top of that, the 18ga metal would be more than strong enough. Especially with the body line across it.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
10-28-2009, 02:25 PM | #13 |
Re: tailgate skins
So the mar-k skin is a cover that slides over the original tailgate? I was looking at the one www.grantkustoms.com sells and the outside tailgate area has to be cut out first. I'm concerned the mar-k skin will stick out too much or does moving in the mounts fix that problem?
Mexican |
10-29-2009, 03:01 AM | #14 |
Re: tailgate skins
I was wondering that too. Do you cut off the old skin or does the full skin just sit on top.
10-29-2009, 03:27 AM | #15 |
78 Big10 454
Re: tailgate skins
The full skin mounts over the existing tailgate. Nothing has to be cut out of the original tailgate, with the exception of the handle relocation flip kit on the inside of the tailgate.
10-29-2009, 11:38 AM | #16 |
Re: tailgate skins
10-29-2009, 05:12 PM | #17 |
Truck Nut
Re: tailgate skins
I have a mar-k full skin on my tailgate. I didn't even weld it. I used panel bonder. They use it on cars to glue qtr. panels on with. You can adjust your tailgate around to compensate for the added thickness of the skin. Go with mar-k, good stuff.
Tony Kee Texas Square Bodies |
