Old 07-29-2009, 09:25 AM   #1
silvrbreez
silvrbreez's Avatar
Water puddling on the passenger side floor?
Whenever I park/drive the truck during a good rain, I get water coming into the truck and puddling at the base of the passenger side kickpanel just forward of the door sill. It's enough to soak the carpet, but it dries rather quickly.
I've done some troubleshooting and it appears to be coming in from the cowl on the passenger side and then leaking down the far passenger side of the inner firewall and through a few screws holding on the a/c components and firewall pad under the dash in that area.
I've looked under the hood and all the gaskets/seals visible to me without removing the cowl/hood seem to be installed and in decent shape.
Any thoughts on what this water is getting through to get into the cab?
silvrbreez is offline   Reply With Quote
Old 07-29-2009, 10:27 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Water puddling on the passenger side floor?
mine was the seal around the door not the cowl
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-29-2009, 05:23 PM   #3
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Could be your windshield seal.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 07-29-2009, 05:42 PM   #4
silvrbreez
silvrbreez's Avatar
Well I thought I ruled that out.
I did a test spray with the hose isolated at where the hood and cowl meet. I saw water getting in the void where the hood hinge mounts. Then I saw water in the floorboard. Up to that point, I hadn't sprayed the windsheild.
Old 07-29-2009, 07:53 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
mine did the same thing so I completely closed up the cowl opening with a/c tape no problems after that
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-29-2009, 08:03 PM   #6
bumslie75
bumslie75's Avatar
i had a 93 s10 and it was the heater core not sure if its in the same place on your truck
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
bumslie75 is offline   Reply With Quote
Old 07-29-2009, 11:08 PM   #7
jdurant
mine leaked from the kick panel area. The seal/gasket around the a/c circulate flapper thingy was leaking.
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 07-29-2009, 11:33 PM   #8
texasfunk
texasfunk's Avatar
mine is doing the exact same thing, but its the heater core
texasfunk is offline   Reply With Quote
Old 07-30-2009, 07:39 AM   #9
silvrbreez
silvrbreez's Avatar
a/c tape? Like insulated tape. You did it from the inside after removing the dash? Tell me more...
I need to check that too. I thought it look pretty dried out and crappy when I replaced my kickpanels a few months back.
so that would leak all the time and not just when it rains right? my problem is only when it rains.
Old 07-31-2009, 10:34 AM   #10
Greenlee
Greenlee's Avatar
I have had this problem a couple of times with my 76'. The first time the water was coming from the cowl area. The factory seam sealer was cracked and deteriated. I covered the seam with some black 3M sealer I got at the auto parts store and that fixed it. A couple of years later it started leaking again. I initially thought it had to be coming from the same area, but it turned out it was coming from the seal around the vent on the passenger side kick panel area.
Use a waterhose and see if you can narrow down where it's coming from.
I try to keep my truck in the garage most of the time now because I'm paranoid that it will spring another leak when it rains!
Greenlee is offline   Reply With Quote
Old 07-31-2009, 11:52 AM   #11
silvrbreez
silvrbreez's Avatar
Thanks Greenlee.
I've done a spray test with the hose and it's defintely coming in when I spray the cowl. From all you guys have said, I'm figuring it's got to be something with the seal behind the hinge or that vent seal.
