07-29-2009, 09:49 AM | #1 |
great southern land
power steering box question
g`day all, i need a part for my steering box, what years have the same box? i have an 86 2wd c10, are the steering boxes the same from any other years like 80 and up or are they year specific?
thanks.
rod 86 chevy c10 silverado |
07-29-2009, 10:02 AM | #2 |
Happy to be here
Re: power steering box question
Rod I know there was a change from SAE to metric fittings, but not sure what year. Early 80's I believe.
07-29-2009, 10:22 AM | #3 |
great southern land
ok, well mines all in metric, was there any diffrence in shape of the little square cover where the adjustment screw is?
07-29-2009, 12:00 PM | #4 |
i know there was a change inside the box in '78. there were different part #'s between '76 and '78 (bought one last week). i think the only difference was like a 1/4 turn lock to lock. notsure on the box on the top though. there's some pics of mine upclose on the last couple pages of my build...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
07-29-2009, 12:34 PM | #5 |
just remembered... keep in mind that small box is for the steering adjustments so put it back together just like you took it apart. maybe count the # of turns on that nut. i remembered this because there was a funny little printed note in my box that says "i know its difficult, but please resist adjusting. our steering gear boxes are set and adjusted to factory specs."
07-29-2009, 01:22 PM | #6 | |
1976 K15 Short/Step 1981 C10 short/wide 1994 K1500 ECSB |
07-29-2009, 02:16 PM | #7 |
napa
07-31-2009, 02:51 PM | #8 |
I was going to rebuild mine too, but for a 130 bucks I took the easy way out. I went to advanced auto. So far so good.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
07-31-2009, 11:44 PM | #9 |
great southern land
well over here its not that easy to just go buy another one, so i gotta get it rebuilt by a steering shop.
08-01-2009, 12:14 AM | #10 |
is there any adjustment in the box to take care of slop? ive got a ton of play in the steering wheel on my '73 i'd like to get rid of. kinda scary to drive at high speeds.
-mike |
08-01-2009, 07:20 PM | #11 | |
Ironmonger
Did that for my '91 R2500 Suburban shortly after I got it, the improvement over the stock dial-a-wander no-effort steering was enormous. I think they can even go a bit stiffer if you want (I *think* a lot of Z28s used 33oz spool valves and the WS6 Trans Ams were 35 or 36 but I might be a little off.) I'd originally planned to convert to a straight-ratio steering box but he talked me into keeping the variable-ratio box, that being a little slower on-center was a good thing for towing. I can't argue with the results. Last edited by JEM; 08-01-2009 at 07:28 PM. |
