07-29-2009, 10:51 AM | #1 |
Transmission Cooler Upgrade
Well I'm running a TH400 in my K10 and chose not to run the tranny cooling lines through the radiator. I figure its hot enough here to just let the radiator take care of the engine heat and a seperate cooler to take care of the tranny heat. The engine runs cool no matter what conditions I'm in and the tranny runs at 160 deg. in normal traffic conditions. BUT when in long heavy traffic lines for a long time at idle the tranny temp creeps up to 210 deg. And when backing the trailer into position at home (very,very tight place) the temp gauge on the tranny pegs. I'm using a 6 pass tube and fin cooler mounted in front of the radiator. Not being known for half measures I have two 16 pass- stack type coolers coming in and each has a cooling fan on it. that gives me a 32 pass cooler with fans. Do you think the tranny pump will pump through that? Oh yeah, I also have a tranny oil filter up front. heres a link to the coolers http://www.summitracing.com/parts/DER-15900/
07-29-2009, 01:02 PM | #2 |
To The Levy
Re: Transmission Cooler Upgrade
Yeah Gator I can feel ya , I installed a somewhat modified 700r4 in my truck and I pull a 22 ft. trailer at times with it and I have seen the temp. go to 230 d. F. I was told that it should never see 220, well I surpassed that number, I also have a cooler running through radiator and than into an external cooler, I have yet to figure out the benefits of running it straight to an external cooler and not through radiator also.
I did see the cooling fan and external cooler combo that summit offers, (you shown link) , not too bad of a deal, I think I would like that , but I just purchased some other goodies for truck , will have to wait a bit on next purchase, good luck on your temp drops on your side. |
07-29-2009, 01:38 PM | #3 |
that works for you guys that live in the sun belt, but up here or anywhere there is winter, you need the rad to heat up the tranny oil.
1972 GMC Sierra 1972 GMC Super Custom Suburban |
07-29-2009, 02:19 PM | #4 | |
Up north here we go hot tranny to external cooler to tank in radiator to warm it up then back to tranny. I installed a temp sender in my tranny so I could keep an eye on things while I'm towing.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-29-2009, 07:04 PM | #5 |
Our winters are too dang hot. We are lucky to see 30 DF during hunting season way out in the woods. Usually we are wearing short sleeve shirts and sweating all season. The last thing my transmission needs is more heat. In fact the last time I saw 30 DF was six years ago. I'm thinking I can switch one fan to reduce the cooling when I don't need it and cut it on when the need arises. I figure that if the tranny isn't going into the radiator to be cooled the radiator only has to cool the engine and the external coolers take care of the tranny heat. Of course that won't work up north.
