Old 07-29-2009, 12:48 PM   #1
vegaschevy
rear diff lube
I am going to change out the rear diff lube on the truck I just picked up. What is everyone finding works great how much and if it is a factory POSI does it need an additive?
vegaschevy is offline   Reply With Quote
Old 07-29-2009, 01:02 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: rear diff lube
Some info here
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-29-2009, 01:06 PM   #3
vegaschevy
Re: rear diff lube
Originally Posted by CPNE View Post
Some info here
thank you, headed to get some 90w oil and some GM additive...
any idea how much goes in it?
Old 07-29-2009, 01:13 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: rear diff lube
approx 2-3 quarts. The instruction on the additive may specify exactly
Old 07-29-2009, 03:33 PM   #5
vegaschevy
Re: rear diff lube
nope, just says one bottle per diff, is there a fill hole on the diff? I guess I could go look. Fill till it comes out?
Old 07-29-2009, 03:36 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: rear diff lube
Thats what most people do. I'd put the additive in first obviously. IIRC the fill hole on a 1/2 to is on the passenger side of the diff somewhere. I deal with mostly 3/4 tons which have the fill hole on the diff cover.
Old 07-29-2009, 04:04 PM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: rear diff lube
Hey vegaschevy....pick yourself up a Haynes manual too....has lots of good info in there too....BTW, my fill hole was on the passenger front side of the pumpkin....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-29-2009, 04:41 PM   #8
cdowns
cdowns's Avatar
Re: rear diff lube
ROYAL PURPLE no need for additive with it
Old 07-29-2009, 04:47 PM   #9
BCOWANWHEELS
Re: rear diff lube
i run 85-140 amsoil synthetic with gm additive if its a posi. . you,ll never have to change lube again as its good for 250k miles. 90w is too thin IMO. BEEN A MECHANIC FOR 40+YRS.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 07-29-2009, 05:00 PM   #10
vegaschevy
Re: rear diff lube
you couldn't pay me to run ANYTHING with AMsoil junk not even my lawnmower
Old 07-29-2009, 05:04 PM   #11
capev86
Re: rear diff lube
Mobil 1 and Valvoline make 75 or 80W-90 synthetic gear lube. probably a good idea as the pumpkin gets worked hard and the fluid usually doesn't get changed very often.
when i swap the ho52 in my 72 burb to a 4.10 (has stock 4.57) i will be running super expensive royal purple synthetic gear oil because my truck is going to do a lot of towing over the coming years!
capev86 is offline   Reply With Quote
Old 07-29-2009, 08:16 PM   #12
BCOWANWHEELS
Re: rear diff lube
i run amsoil in all my semi trucks for over 20 yrs now without a single problem except its $$$$$$$$
Old 07-29-2009, 08:49 PM   #13
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: rear diff lube
For what it's worth, I been running the same Amsoil 80wt. gear lube and GM additive in my GM corp. Posi that I put in twenty years ago and no sounds, no problems.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 07-29-2009, 09:19 PM   #14
vegaschevy
Re: rear diff lube
alot of things would work in a diff or a motor for that matter.
however, a multi level marketed product that is endorsed by no one is not something I would run out and purchase. Not to mention most their oils are not approved by many if any companies
