Old 07-29-2009, 01:07 PM   #1
kevs84s
drive shaft interchange?
Hello. im new to the site and my 67 swb step is new to me. i have a bad vibration @50-55 mph, found my drive shaft to be not quite straight. truck is running s 350,th350 combo. what other year model shaft will fit. thought if i had some options, finding one would be a bit easier. thanks for any and all help with this, it is greatlly appreciated.
kevs84s is offline   Reply With Quote
Old 07-29-2009, 03:02 PM   #2
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
Re: drive shaft interchange?
I would pull the driveshaft and take it to a shop.
They will retube and balance it for around $100, turn around is usually
24hrs. I payed $120 and got new ujoints.
Jack_71C10 is offline   Reply With Quote
Old 07-29-2009, 06:13 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the prices fluctuate quite a bit from area to area, but I would recomend the same thing though.
Old 07-29-2009, 07:33 PM   #4
mclairmo
I agree, it needs to be straightened and balanced or tube replaced. Another used one could be bent, too, and/or unbalanced. Cheaper in the long run to have a shop check it out.
mclairmo is offline   Reply With Quote
Old 07-29-2009, 11:50 PM   #5
kevs84s
Well i was in a hurry earlier today when i first posted, there is a little bit more going on underneath my truck. the shaft isnt riding through the center of the crossmember, more off to the pass side, and the output shaft of the trans seems to be a little sloppy. is the shaft supposed to be dead center in the crossmember? how much out of straight does the shaft have to be to cause a issue? i realize straight is straight but is there some tolerance? thanks again.
