The same or different??
Is the cab and doors of a non ac 1968 gmc the same as a non ac 1969 chevy?
member #16
![]() Join Date: Dec 1999
Re: The same or different??
The doors should be the same, the cab has A/C ducts in the dash and the firewall is different.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Ok thanks, so if there both non ac cabs then they should be the same right?
#4 | |
Resident Curmudgeon
yes
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
member #16
Depends on yr. model. 71-72 models changed to throttle cables instead of rods. 67-68 had a hand pull emer. brake. 69-72 had a foot pedal. Those are the main obstacles.
