Old 07-29-2009, 05:50 PM   #1
77chebby
Th350 slips at full stop.
my th350 in the 79 silverado slips at full stop sometimes. never slips changing gears and rides great in 2nd or 3 rd but when i come to a complete stop it revs a little before clunking or chattering a bit(under hard acceleration) and moves, then its fine. only does this after its warmed up. i changed the filter and fluid and gasket (it was leaking enough that it was hard to tell if i was keeping the right amount of fluid in it.) . the pan still leaks pretty good, could be warped or something. anyways any ideas on the slipping ? only does it at full stop after its warm. thanks guys , mark
77chebby is offline   Reply With Quote
Old 07-29-2009, 06:19 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Th350 slips at full stop.
check fluid
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-29-2009, 07:25 PM   #3
60ratrod
yes, i do
60ratrod's Avatar
next time you check the fluid, smell it. it could be that your clutch plates are getting burnt up. the fluid will smell burnt
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 07-29-2009, 07:42 PM   #4
77chebby
thanks guys , but the fluid is where its suppose to be( best i can tell) though it leaks pretty good so hard to decide if while driving it if it stays accurate. fluid is new smells and looks fine and is still slipping a little...
Old 07-30-2009, 02:44 AM   #5
texasfunk
texasfunk's Avatar
try some trans x, its pretty pricey but CAN work miracles, stopped the slipping on my 93, and on the pan, next time you rplace the gasket be very careful not to over tighten the bolts or you will crack the gasket, and also befoe hand, get a hammer and dolly and flatten the bolt holes, sometimes with tightening it turns them into a small "crater" and it will also cause it to leak, hope this helps!
texasfunk is offline   Reply With Quote
