Keep Your Nose Clean
Firewall.....What are these holes for?
Greetings folks. I'm getting ready to fill in the firewall but don't have any idea what these holes are for and if they should be filled in. I'm running a carburated SBC mated to a 700R4, power brakes, and an aftermarket A/C. Thank you for any help you can provide. MisterE
Restoration Virgin!
Re: Firewall.....What are these holes for?
I couldn't find a pic that soemone did showing what all those holes are for, but I did my best to label some of them for you....what year is the cab??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 07-30-2009 at 02:28 PM. |
#3 | |
![]() Last edited by MisterE72; 07-30-2009 at 03:28 PM. |
Restoration Virgin!
Not sure what they are for....but I did remember in the 2nd photo the one I didn't mark is for the intermediate wiring harness that runs from the firewall to the rear cross sill for the rear tail light connections...sorry....i know someone will post up a pic of that firewall...I'll keep looking too!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
![]() Join Date: Feb 2009
the two bigger holes in pic one are left hole if foe the cable from the heater controls it opens the flap on the outside heater box for the ac and the other is for the wires the go the the fan motor, graound on the fan motor and the other i believe goes the ac compressor but im not for sure i cant find it on a wiring diagram anywhere longhorn would probaly know hope this helps
Sr. E if you want a clean firewall only leave the holes I left, if you need to you can always redrill....
Small block Classic auto air Nothing else on the firewall but the harness...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Here's that drawing. The holes on the passenger side are for A/C control hoses and wires.
Restoration Virgin!
yep....that's the one I was talking about!!!....Thanks Dynamutt
![]() Join Date: Jul 2007
The holes in pic.1 are. Left hole Control cable fir the heater. The hole on the right is for the Vacuum lines to open the heat control valve and also the line going to the vac. Ball it also allows for a line back into the cab to feed the vac. switch on the ac. control.
Are most folks replacing the firewall insulator pad? I'd like to fill in the little fastner holes for that too. I imagine the insulator pad can be glued on using 3M contact cement instead of the fastners.
Restoration Virgin!
Yep...you can fill those holes....just use dyna-mat, fat-mat, maybe lizard skin or whatvever you want to insulate the cab!!!
My neighbor Isaiah and I got started in it today. More to come later.
#13 |
Old thread, found using search! Haha how neat... thanks for everyone here btw!
