Old 07-30-2009, 02:10 PM   #1
setelec 73
setelec 73's Avatar
Need Help with OEM wheels
Just curious on what you think origanally came on my truck as far as wheels?? It appears by my researching that the caps that are on this truck now could be wrong for the year. It is a 1973 3/4 ton camper special. I am trying to find some affordable tires and rubber for it. Have a hell of a time finding 8lug rims and no luck at all finding 8 lug rallys!!!.. So question is.. Are these my original wheels and caps that came on this truck? If so I will just replace tires and caps and not worry about wheels. I want to put on about a 31" tire to be safe as the truck has no lift on it... Please see old pic and I hope to have some new ones with my progress shortly... Thanks everyone
1973 3/4 Ton Chevy 454
1990 Ford Ranger 4.0
2002 Cadillac Deville
setelec 73 is offline   Reply With Quote
Old 07-30-2009, 02:45 PM   #2
geunther
geunther's Avatar
Re: Need Help with OEM wheels
They appear correct to me. We had the same truck when I was a kid and it had those. Ours had 16.5 wheels. There were no rallye wheels for 3/4 ton trucks in 73, and if I remember correctly they did not even come out for 1/2 tons until a few years later.
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
Old 07-30-2009, 02:54 PM   #3
setelec 73
setelec 73's Avatar
Its just when I see the hubcaps at LMC or anywhere they dont show 73 as a year for them?
Old 07-30-2009, 02:57 PM   #4
cochino12
It followed me home?
cochino12's Avatar
Sorry no help here but that is a good looking truck
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-30-2009, 04:12 PM   #5
Dooley
Dooley's Avatar
The original wheels would have been 16'5" rim. Stock tire was 8.75/16.5, with options of 9.50/16.5, 10.00/16.5 and a 7.50/16" tire on 16" rim. Unless going for factory stock I would change to a 16" rim for greater tire availability and cheaper tire replacement cost. Those hubcaps will fit GM 16" rim also. You should be able to run a 235/85-16 with no problems.
Dooley is offline   Reply With Quote
Old 07-30-2009, 04:34 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The front hubcap is correct for that year, the rear hubcap came out in the later 70's I think around 1979?
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 07-30-2009, 05:35 PM   #7
setelec 73
setelec 73's Avatar
What are the differences and where can I find the right ones??
Old 07-30-2009, 05:37 PM   #8
setelec 73
setelec 73's Avatar
Also would they have been white like they are now?? The actual wheel?
Old 07-30-2009, 06:20 PM   #9
The hubcaps with the yellow bowtie in the center should be the same for 3/4 and 1 ton single wheels from 1973 up to 1978 or so. They turn up on Epay once in awhile, local junkyards are a good place to look too. As for the wheels every one I've seen around here on the older 3/4 tons has been white, usually still has the original paint too.
RJD
Old 08-29-2009, 08:19 PM   #10
spyder4560
spyder4560's Avatar
Try you a set of the newer 8 lug alloys from 2500 HD trucks.They came out from 2000-2008 and work perfect on older trucks.I have a set on my '69 GMC and they look good.Only trouble is that you have to get the right lugnuts to use the center caps.
spyder4560 is offline   Reply With Quote
