Old 07-30-2009, 02:58 PM   #1
bigguy69
dazed and confused
bigguy69's Avatar
get your grill to shine
and i am not talking about teeth here, hehe.i have a 69 and a 70 chevy trucks. what is the best way you found to bring the shine back on the metal part? also how do you remove small scratches? thanks in advance.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 07-30-2009, 03:17 PM   #2
mclairmo
Re: get your grill to shine
I use Autosol or Simichrome from Eastwood. Better than anything Butt Boys has.
mclairmo is offline   Reply With Quote
Old 07-30-2009, 03:48 PM   #3
ZombieWeinerDog
ZombieWeinerDog's Avatar
just had to show you my shiny one
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 07-30-2009, 04:24 PM   #4
bigguy69
dazed and confused
bigguy69's Avatar
looks good what did you use?
Old 07-30-2009, 04:41 PM   #5
ZombieWeinerDog
i used turtle wax aluminum polish, it says dont use on chrome, but it works better than chrome polish. its also new from lmc.
1972 longbed- 454
1967 shortbed- 355
Old 07-30-2009, 07:59 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll have o remove the clear coat/clear anodizing off the grill before you can make anything shine.
Old 07-30-2009, 10:33 PM   #7
mas09ts
mas09ts's Avatar
I used oven cleaner to get the old coating off, then used alum. polish, its shiny!!!
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 08-22-2009, 06:17 PM   #8
big mike71
big mike71's Avatar
How long do you leave the oven cleaner on, and do you think you could tape off the paint and do it while it's on the truck.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 08-22-2009, 06:20 PM   #9
vegaschevy
I would not let pven cleaner get close to anything you did not want it on. that stuff is very very strong...... eats the finish off anything.
vegaschevy is offline   Reply With Quote
Old 08-22-2009, 06:35 PM   #10
Rack Man
He's correct....I use 'Very Fine" Steel Wool....and then buff it out!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 08-22-2009, 06:57 PM   #11
vectorit
What?
vectorit's Avatar
Doing all of the above will just be an on going battle of polishing, since the parts are aluminum and will oxidize and turn dull after a short period.
You will need to have it re anodized.
I did this with the rear sections of my side trim for my burb, which nobody reproduces yet.
My stuff was nasty from years of dents, scratches, and even a portion that had a rip. These guys fixed it all for me, and when I got it back the stuff looked OEM new. The only thing they didn't do was paint the black stripe, but from their website it looks like they may be doing that now. Since when I did my business with them, they were just getting their shop started.
Check em out. I was very pleased with the price and workmanship.
http://www.kingoftrim.com/
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-22-2009, 07:08 PM   #12
big mike71
big mike71's Avatar
My grill has kind of rainbow effect going on if you know what I mean. Like when you have oil in a puddle
Old 08-22-2009, 07:25 PM   #13
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I got something called Duragloss 870 aluminum polish from NAPA for about $10. I works real well although it's really for aluminum wheels. I'm not saying it's the best but I like the results.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 08-22-2009, 09:08 PM   #14
bigguy69
dazed and confused
bigguy69's Avatar
those king of trim guys look good!
Old 08-22-2009, 09:16 PM   #15
70Custom10Nut
70Custom10Nut's Avatar
I had that same question going through my mind. I used a chrome cleaner from Eagle to clean the oxidation off my aluminum wheels. (be advised that the warning said "do not use on aluminum") and they shine like you wouldn't believe. I was seriously considering using it on my grill. My grill is in perfect shape but it's just "milky". Justifying a new outer grill for $500-$800 is hard to come to terms with for a daily driver/hobby. I was wondering if I could use this cleaner then spray a clear coat to seal it? Would this get the desired effect? Any ideas? Cnut
70Custom10Nut is offline   Reply With Quote
Old 08-22-2009, 09:33 PM   #16
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
A simple way to freshen up the old grill shell is to powdercoat in "near chrome" color. You have to remove the grill from the truck and the inner plastic, but you can blast and coat the grill shell with the end brackets still attached.
PICKMUP is offline   Reply With Quote
Old 08-22-2009, 09:35 PM   #17
redbaron69
redbaron69's Avatar
BIGGUY, we have wet sanded this kind of stuff at the shop with 1500 grit to remove the scratches and then polished turned out good, come see me sometime.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 08-23-2009, 04:21 AM   #18
oldschooler
oldschooler's Avatar
0000 steel wool and some elbow grease.
oldschooler is offline   Reply With Quote
