Biggest Tires with stock suspension?
I was wondering if any of you guys have any in-sight as to how big of a tire I could go on a stock Silverado....the Control Arms are up as far as they will go in the front. I will cut a bit of the front bumper skirt if need be.
Thanks ![]()
93' 1500 Silverado Ext. cab Fullsize bed. Dual exhaust with Chrome tips, Exiting at the rear. |
Also:
I am hoping I can put ATLEAST 31's on it.
![]() ![]() Join Date: Jul 2002
My 96 has had 31x10.50-15 on 8" SS wheels and no clearance problems. (front or rear). I think I have see another guy near my work and he has 32x11.50 on his 2wd and it looks like they clear OK also.
Alright, thanks
![]() Time for some Baja Claws ![]() ![]()
Alright, thanks
![]() Time for some Baja Claws ![]() ![]() While i'm with the tires...would you guys recommend getting Powertrax, or Lockright lockers that don't sound harsh like the rest?
Do you have a pic of your truck?
Don't have a picture with the 31's on it, but this is with 275/60. the 31's are about an inch taller and slightly narrower. I went to street tires to be a bit quieter and since I wasn't going to do any serious hauling with this one.
Do you think I could fit 33's, or would that be on the ragged edge?
?? Any ideas?
Dunno. I think you'd be pushing it a might.
4 speed, hurst shiftin
id have to check but im preeeeetty sure on that year chevy , you can fit 33s, but they rub when flexed, im not quite sure, i know for less than 150 a cheap 2 inch body lift would fit 33s anyone agree? oh , is it a 2wd or a 4wd?
Shane 1970 Chevy C10 |
It's 4WD.
thanks
#13 |
33 x12's
I have put 33 x12 on the rear of mine for snow and mud and they are OK until you hit a dip or hole. They WILL RUB on occasion! I think putting them on the front would be risky at best. I'd stick with 31's if the'll do. nuideas
#14 |
on a 4X4 33-12's should fit all around... Pete
1968 Chevy - 3/4 Ton - 4X4 - Longbed - 383ci - TH350 - NP205 Building the motor, painting the engine bay, rewireing everything... (775)-527-1199 / ryanspeterson@msn.com |
#15 |
oh, sorry I am thinking 67-72 years... on a 93 4X4 I think 32 is as good as it gets and they will rub a little but not to bad- I cant remember the the 3 letter equivalant (295 or 305? or something like that)... Pete
#16 |
Thanks fellas, I think I'm going to go with Lockers and some 31 inch tires.
Thanks. ![]()
#17 |
Big Block Power
You can put a 305/70 under it but will need 8" wide wheels, with 5" of back spacing, they are close but they fit on the 1/2 tons, same combo on my dads 98 Tahoe, and on the 3/4 tons just crank torsion bars up 4 turns and the will fit that too!!
#18 |
Project92 SWB stepside
33's will go on a 4x4. I have a 94 3/4 ton 2wd and they fit on with 33x12.50 on a 15x10 wheel. I did trim the front air dam and later added a 3" body lft to keep from rubbing on bumps!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#19 |
![]() Join Date: Feb 2003
Palf70step: Is your 70 step lifted in the rear? I have a 68 step and it sits much lower, rear is about same height as front.
Thanks! |
#20 |
68_Step No mine is all original suspension. Although mine was ordered with HD suspension/springs (owner hauled cattle)
