Seņor Member
Cutting holes in a perfectly good hood
I've been stewing on this project for quite a while, and thanks to some CAD work by slammed67, some machining by mekdad, much finagling by rokcrln, and way too many pesos, it's time to post pictures.
First, you've got to yank a nearly new Holley 390 4bbl. Then you've got to cut on a perfectly good Clifford manifold.
Seņor Member
Re: Cutting holes in a perfectly good hood
Next, you take the Vintage Speed 3x2-to-4bbl adapter as the conceptual model, and a zillion different measurements, and feed them to slammed67, who turns out some CAD files.
Note: There's a fundamental interference problem with running an off-the-shelf 3x2 setup. It's called a firewall. And, this isn't a hot rod, but rather, I'm trying to achieve a particular style. With that in mind, the manifold may not seem so odd after all.
Seņor Member
After a few mid-air adjustments to the design, waiting for the brown truck to arrive from points far and wide, and 17 trips to the hardware store, you end up with this assembly...
Seņor Member
Once this contraption is mounted on the motor, you'll find that there's a clearance problem with the hood... but that, ladies and gentlemen, is the essence of the plan
Seņor Member
Now, you've got to solve that clearance problem with the hood...
Seņor Member
... and make it look like you actually had a plan...
Seņor Member
Build a bit of dimensionality into the holes. Flat holes are so... flat.
Just Not Low Enough!
thats lookin pretty fancy there, cant wait to see the finished product!!!!!
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
You are brave, I would be scared to cut a hole in the hood. How will the fuel distribution be with the front carb so far away and the back carb right on top of the opening to the plenum? Will you have to jet that back one lean and front one rich? How do you balance them?
Seņor Member
Weld...
VA72C10
![]() Join Date: Mar 2008
Very cool. I like your build because you're willing to really step outside the "box" and do things no one else has tried. And everything is executed very well. Good work!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Seņor Member
Do the finish work and prime...
#13 |
Seņor Member
Voila...
#14 |
Awesome!
#15 |
that is some wicked stuff, do you have a shot a lil further away?
#16 | |
Seņor Member
Actually, if you study this pic closely, you'll note that the fuel inlets on the front 2 carbs are plugged. The front 2 carbs are externally fully functional dummies. All the linkage on them works, but they don't squirt fuel. In fact, while my log manifold has pockets under the carbs, they don't connect with one another. What I have is a 2bbl carb with a straight shot into the manifold. Simplicity at its finest ![]()
#17 |
That looks really cool your truck is gona be nice
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#18 |
VA72C10
Very cool!
#19 |
The added bonus is that you now have 2 spare carbs!!
![]() Dan
Dan Smith Colorado Springs, CO 71 GMC Custom Camper "Longhorn" 454, TH400 73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny "DON'T TREAD ON ME !!!" My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442 |
#20 |
BOHICA
That is the coolest thing I have ever seen!
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
#21 |
that is really nice engineering on all parts......did mekdad mill the new manifold??
#22 |
Cowboy Fan for Life!!!!!!
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
#23 |
"THE GREEN GOBLIN"
That looks awsome good work you did there.. I have one question though will the motor move, and cause the carbs to rub on the hood on acceleration like torque?
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#24 |
That is Awesome! Nothing like good old American Engineering!
MrBlue |
#25 |
![]() Join Date: Aug 2005
I like it, I like it ahhhlot.
