07-31-2009, 08:53 AM | #1 |
How much to cut cups?
My truck is an 86 and I have the S.D. cups. I've searched and see varying opinions on cup heights between 1-1.5". I'm running a sway bar too. Just wanna run some schrader valves to keep it simple. Thanx
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
07-31-2009, 11:20 PM | #2 |
Re: How much to cut cups?
My understanding is that you can go to 1.5" on 67-72 arms and down to 0.75" on 73-87 arms. I have no exp with the 73-87 arms though. 1.5" cups are perfect for my '72 arms.
08-01-2009, 11:09 AM | #3 |
anyone with a 73-87 please advise me. I have 2 1/2 drop spindles too.
08-01-2009, 12:03 PM | #4 |
Happy to be here
I don't know the correct answer, but I am curious why you are cutting them?
08-01-2009, 02:55 PM | #5 |
Laid Lo
Probably to get a bit lower when aired out.
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
08-01-2009, 03:06 PM | #6 |
i need this info too...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
08-01-2009, 10:05 PM | #7 |
08-02-2009, 02:28 PM | #8 |
low n' slo
is this true for the 67-72 trucks too?
08-02-2009, 03:38 PM | #9 |
Happy to be here
I "understand" that cutting the cups allows you to go lower. Does it allow you to run more air at a lower ride height?
On my 82 Blazer with 3" spindles and standard cups, the limiting factor was the A-arms hitting the ground. Ok, school me on this guys.
08-02-2009, 07:19 PM | #10 |
The cups S.D. sent are 2.5 inches high..... I had a feeling that was too much. I have a 2.5" drop spring in there right now and it's to harsh. I like the stance but was hoping for an improved ride. I'm still not clear on what the ideal cup height should be. If I can't get a solid answer, I'll probably try 1.25 and go from there.
08-02-2009, 08:31 PM | #11 |
TNT-MOTORSPORTS
If I understand correctly, The shorter the cups, The more air you can run in the bags, The better the ride........???? Correct......????
08-02-2009, 09:54 PM | #12 | |
86 C10
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
08-03-2009, 08:46 AM | #13 |
so you cut it down to 1.25 and you can lay control arm?
08-03-2009, 09:08 AM | #14 |
I wish I knew for sure, but no one has confirmed this so I have to start somewhere
08-03-2009, 09:23 AM | #15 |
cool bro, keep me posted please
08-03-2009, 09:27 AM | #16 |
no thats not it the less air you run the softer the ride, just has to do with how low it will go when aired out...
08-04-2009, 01:06 AM | #17 |
Actually there is a range in which a bag will give the best ride. Pressure/bag-height too low=crappy ride & pressure/bag-height too high=crappy ride. Other factors like selecting the right bag for the application also come into play. In general, with the right bag for the application shorter cups allows you to ride lower and still be in the "sweet spot." ...and obviously air out lower.
08-04-2009, 07:18 AM | #18 |
Thanks for schooling me mike...LOL. does the sweet spot depend on the bag or is there a pressure we should be shooting for? I have 2600 dominators.
08-04-2009, 08:39 AM | #19 |
low n' slo
I got the same sd cups, so I would mine down too for more of a lower drop? 67 suburban
08-04-2009, 02:03 PM | #20 | |
Linkage here Yes. 1.5" total cup height works well for 67-72 arms. |
08-04-2009, 02:29 PM | #21 |
Cool thanks again mike!
08-04-2009, 07:12 PM | #22 |
how bout 73-87 arms??
08-04-2009, 08:38 PM | #23 |
low n' slo
according to this very thread yes the 73-87 arms too. the guy who started the thread has an 86....
08-04-2009, 10:39 PM | #24 |
I've read guys say they can cut more off the cups when using 73-87 arms. Maybe someone can confirm to clear this up once and for all...
08-05-2009, 05:44 AM | #25 |
low n' slo
what happens if u would cut it down to like an inch or even less?
