what are u guys doing about the seam on the back of cab
i m all most done body work but i don't know what to do with this seam option 1 = clean it out and move on. option 2== weld it up and move on. so what did u do
Under Construction
Re: what are u guys doing about the seam on the back of cab
cleaned. cleaned. cleaned.... Then welded the seam.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
I would clean it out and move on, it is what we did.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Between Trucks...
You might kick yourself later on if you don't go ahead and weld it up now.
Beat it to fit, Paint it to match... ![]() |
I think clean clean clean and weld her up. Looks way nicer that way
big AL did u go with just cleaning or did u put some kind of sealer in it i want to weld it up but I'm tired of welding i want to start driving and sinister i know u are right about kicking myself later on if i don't go ahead and weld it up now. i hate f--king decision lol
__________________ |
If you don't clean and weld now, you will murder youself when rust forms there later. Sealer is temporary, welds are forever.
I cut mine open and removed about a 1/4 inch then welded it back up to round off the back of the cab
#9 | |
I know about descisions, my body guy just cleaned it and used a sealer I dont know what he used but I could find out for you....Mine is been done for over a year now and I have no regrets...
i did this one in 2002 and it still had no rust and all did back then was paint right over it so i thank i will go that rout again. I'm getting lazy lol
Active Member
![]() Join Date: Jul 2007
I've got a 68 and a 69. Up until a few years ago, both had the original paint without any rust.
I'm one of those that like the original design look so, I say if it isn't rusted just seal it and with a good paint job you shouldn't have any trouble. Check with the paint shop to see what sealer they recommend. Last edited by 68gmsee; 07-31-2009 at 03:13 PM. |
I just finished mine up as well. Cleaned it really good and put seam sealer in it. I guess I'll find out if that was the best thing to do or not.
#13 |
CAN'T FIX NOTHIN
the correct way to do the seam is
#1 clean it out to the bare shiny metal #2 primer it GOOD with urethane or epoxy primer #3 after the primer cure's seam seal it with sandable auto body seam sealer #4 after the seam sealer is dry sand it lightly to obtain a factory look it will last for year's !
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
#14 | |
cool thanks |
#15 |
I`m cleaned and primed it.Now I will seal it and prime again.Weld them if you want a custom look,but I`ve never seen a cab with problems in this area the way the factory did it.
#16 |
Dave's not here, man
I remember a post awhile back where someone took the seam out of a cab. I want to say that it was Porterbuilt, but it was so long ago I can't remember for sure. I will try to find the post.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
