Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-31-2009, 02:05 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
holley stumble?
Neighbors car.
scenario- 347 SBF engine, LX body w/5speed, 4.10 geras.
canfield heads, Air gap intake. Comp Hyd roller. new holley 650 DP. not the HP series.
car snaps when you first touch the pedal then stumbles and blue oil smoke ensues and a 'rich' smell is present all the time. I've already told hime that some out of box holleys are junk, but thought i would give some of guys a chance to chime in. engine holds 6" vacuum at idle. the carb is stock except for #45 power valves.
I already thought maybe too large of a squirter/jetting for the low velocity heads.
Yes, i already told him to put a Chevy engine in it many time over. :-)
crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 07-31-2009, 05:43 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: holley stumble?
Lend him a good tuned, working 750 and see if he is convinced.
Kind of sounds to me like he is sucking oil into the PCV system . The blue smoke would trouble me!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-31-2009, 11:01 PM   #3
crossy
crossy's Avatar
Re: holley stumble?
blue smoke troubles me too for a fresh engine, but i'm not lending him my carb either.
marv, i recognize your truck, belated congrats on the Pinks win.
98 Vortec project.
94,3500,6.5L 4L80
Old 08-03-2009, 06:37 PM   #4
d3mon
Re: holley stumble?
I too would start with dropping the squirter # size by 3 and see how it reacts. This will allow for a slightly longer duration shot.
d3mon is offline   Reply With Quote
Old 08-04-2009, 11:23 AM   #5
Schralper
Schralper's Avatar
Re: holley stumble?
6" @ idle? are you sure? what kinda cam? HUGE?
cuz I have a hard time w/ 6" vacuum
I'm running 234/244 flat tappet in a 350 and have more than that.
have you messed w/ carb already? if so set back to stock settings.
try 1.5 turns out on idle mixture screws to start, 800rpm idle speed.
if it's not 6", try 6.5 PV's, #28-31 squirters, 65 mains.
blue smoke = oil getting into intake somewhere
got good intake/head seal? I had a squished intake gasket @ 1 port and it wanted to suck in oil.
Also had an intake manifold w/ pinhole casting defect that introduced oil into system
what's the timing? 16-18deg initial?
Schralper is offline   Reply With Quote
Old 08-04-2009, 12:04 PM   #6
Marv D
Marv D's Avatar
Re: holley stumble?
Thanks crossy, it was a blast... unexpected, but a blast.
I have to agree schralper is on to something. The backup motor for my Nova runs a Crower roller with 268/274 @ 0.050, and .675 lift. IT has over 6" of vacuum in a Holley Proram with a pair of side-by-side 4150's. I know them furds are wierd, but no hydraulic roller should be that low unless it's some exotic custom grind animal. I suspect something mechanical i.e. busted intake seal like mentioned. That would explain the blue oil smoke.
You could always make him a deal... Lend him your carb for 1 hour, and it it's the POS furd motor, he has to put put the bumpersticker on... you know the one...
I'd rather push a Chevy then drive this POS furd one more inch
wouldn't that be fun
