Old 07-31-2009, 04:56 PM   #1
TCLARK
67 cab on 72 frame
Will a '67 gmc cab bolt up to a '72 chevy frame ? Are they the same except the back window ? Thax!
TCLARK is offline   Reply With Quote
Old 07-31-2009, 05:46 PM   #2
pickupman
pickupman's Avatar
Re: 67 cab on 72 frame
yes they will bolt up fine
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is online now   Reply With Quote
Old 08-03-2009, 08:29 AM   #3
TCLARK
thanx !
Old 08-03-2009, 11:42 AM   #4
TCLARK
the 67 gmc is an automatic and the 72 chevy is a manual........will the pedal just bolt in ? I want to use the manual !
Old 08-03-2009, 11:50 AM   #5
Livrat
Member #1049
Livrat's Avatar
Yes it will bolt up fine.. yes you can use the 67 clutch pedal assembly..
the two major differences are the 67 has a throttle pedal with a rod and the 72 has a cable.. and the emergency brake assemblies and front cables are different
Livrat is offline   Reply With Quote
Old 08-03-2009, 01:01 PM   #6
TCLARK
thanx!
Old 08-03-2009, 04:05 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll probably want to keep the bolt in high hump floor board from the manual truck... this is assuming 4 speed and not 3 on the column.
Old 08-03-2009, 04:12 PM   #8
TCLARK
Originally Posted by longhorn man View Post
you'll probably want to keep the bolt in high hump floor board from the manual truck... This is assuming 4 speed and not 3 on the column.
it was a 3 on the tree.............i put a car 4speed in ! The collar was so bad & i hate 3 on the tree ! I've got a 5speed from an '85 z28 i'm planning to install.
