Old 07-31-2009, 06:03 PM   #1
clos69
Its Topless Season!!!!
clos69's Avatar
A/C vs Non A/C radiator differences
Can someone tell me what is the difference between them? .....I am wanting to buy an A/C for my non-a/c blazer....will this work? thanks
Ps. My current one is a 2core and the one I want is a 4core...
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 07-31-2009, 06:28 PM   #2
mclairmo
Re: A/C vs Non A/C radiator differences
I don't remember seeing an a/c or non a/c specific radiator. I believe an a/c truck would merely come with the larger core radiator. I would go with the 4 core. Both my Camaro and truck have oem brass/copper 4 cores and they are great.
mclairmo is offline   Reply With Quote
Old 07-31-2009, 07:29 PM   #3
clos69
clos69's Avatar
Thanks mclairmo....the reason I ask is cause a boardmember wants to know if I want his from the parts board. He has other people waiting for me who are also interested in it..I guess the question I should be asking is has anybody used a radiator from an a/c truck on a non-a/c truck.thanks
-Carlos-
The of America
Old 07-31-2009, 07:42 PM   #4
brak
brak's Avatar
typically the difference is AT/MT, cause obviously you'd need the tranny cooler if you're running AT...
also, don't forget, if you're not already running a 4 core, you'll need to replace the mounting pads, as the 4 core is thicker.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 07-31-2009, 07:45 PM   #5
mclairmo
I believe that all the radiators bolt in the same way and that there is no difference. I don't believe that the a/c components depend on a particular type of radiator. As such, a radiator from an a/c truck should bolt in the same way to a non a/c truck and work and fit the same. No difference. However, there is a difference between 2 row, 3 row or 4 row.
Old 07-31-2009, 08:01 PM   #6
AJs72K5
AJs72K5's Avatar
Found the difference in the LMC part numbers...didn't look close enough...w/o AC is a 3 row and w/ AC is a 4 row
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 07-31-2009, 10:05 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there are no 2 3 or 4 CORE rads in cars or trucks, that is reserved for equipment that needs a rad about 6 to 10 feet tall. After that, they step up to a modular design.
These trucks came with 2,3, or 4 ROW cores in a copper/brass style radiator.
