Old 08-01-2009, 09:57 AM   #1
slategrove
slategrove's Avatar
trying to install Yearone radio...
I've looked through tons of posts and kind find anywhere that anyone talks about removing the ashtray receiver...I removed the ashtray, but the piece that it slides into doesn't allow me to remove the old radio...can someone HELP?????
Thanks,
Slate
slategrove is offline   Reply With Quote
Old 08-01-2009, 10:09 AM   #2
mclairmo
Re: trying to install Yearone radio...
Is it spot welded to the dash?
mclairmo is offline   Reply With Quote
Old 08-01-2009, 10:12 AM   #3
slategrove
slategrove's Avatar
I'm thinking that it might be since I can't find any screws, etc. But wanted to see what you guys thought before I started popping stuff loose...but I can't get the old radio out
Old 08-01-2009, 10:20 AM   #4
nbrfd007
nbrfd007's Avatar
Pull your glovebox and the radio will come out thru there.
nbrfd007 is offline   Reply With Quote
Old 08-01-2009, 10:44 AM   #5
slategrove
slategrove's Avatar
Ok, I'll try the glovebox....Thanks guys
Old 08-01-2009, 10:46 AM   #6
mclairmo
I agree, don't bust the ash tray track out. There has to be another way to get the radio out.
Old 08-01-2009, 10:56 AM   #7
nbrfd007
nbrfd007's Avatar
It's tight, but you will come out with no problem.
Old 08-01-2009, 02:00 PM   #8
slategrove
slategrove's Avatar
Ended up, diconnecting the hoses to the defrosters, and slid it to passenger side, then out...so I didn't even have to remove the glovebox...
NOW I have another problem, PO had a wire running from + terminal on coil to radio, and was spliced in a couple differnt places with other wires...took that wire out and wired radio to fuse box...radio works great, but when I try to start the truck it dies as soon as you let the key pop back to "run"
Where should that + terminal coil wire go to?
Old 08-01-2009, 03:01 PM   #9
slategrove
slategrove's Avatar
I ended up running that wire from the + terminal of the coil to the "run" side of the ignition, and all is well again...Gus is running, and singing his tunes now.
Thanks guys,
