Old 08-01-2009, 02:20 PM   #1
CrazyIvan
Somebody please tell me what this is called!
Hi, I'm trying to get my door lock to work and traced the problem to the wheel being loose/worn in the mechanism.
Can any one tell me what this part is actually called?
Know what vehicles this part is interchangable with?
Or if it can be simply dismantled and repaired or tightened?
Thanks in advance
CrazyIvan is offline   Reply With Quote
Old 08-01-2009, 02:49 PM   #2
hilandr452
hilandr452's Avatar
Re: Somebody please tell me what this is called!
It's called a door latch assembly. Here's a link.
http://www.bobschevytrucks.com/1967-...chevy-gmc.html
Dan
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 08-01-2009, 04:20 PM   #3
CrazyIvan
Thanks,
Thats what I needed, I'll try the wreckers first see if i can save myself some cash.
Old 08-01-2009, 04:21 PM   #4
Green Machine
Green Machine's Avatar
Not much fixing on those, either find a good used one or replace. The star wheel is supposed to turn on the little axle in the center, but usually the wheel rusts to the little axle pin, then the whole pin and wheel starts to spin in the hole at the end and then it gets pretty sloppy.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-01-2009, 04:29 PM   #5
JesseSimon
Asks alot of questions
JesseSimon's Avatar
No need to mess with the boneyard, Ive got one, I sent you a private message
MY STABLE:
'66 C10 LWB turning it into a shortbed stepside
'77 LWB (my daily driver).....oh its a FORD ahhhhh!
'07 MAZDA 3 (the wife's ride)
JesseSimon is offline   Reply With Quote
Old 08-01-2009, 04:29 PM   #6
CrazyIvan
Smile Re: Somebody please tell me what this is called!
ah, gotcha,
Thats defo whats happened with mine.
Just tried to take the door panel off but couldnt get the inside handle off. Realized that I think I need a maintenance manual, would you suggest chilton or hanes for a novice like myself?
Old 08-01-2009, 04:44 PM   #7
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
hit up a parts store and pick up the tool to remove the inner handles. there is a small wire clip on the back of the window crank and door handle. use the tool and the clip and handle will pop right off.
stealthy '69 is offline   Reply With Quote
Old 08-01-2009, 05:53 PM   #8
big mike71
big mike71's Avatar
When you put the handle back on just put the clip on and then push handle back in place it's easier than trying to get clip on afterward.
big mike71 is offline   Reply With Quote
Old 08-01-2009, 06:00 PM   #9
big mike71
big mike71's Avatar
Ivan I just took mine apart not to long ago, there are alot of rods with little c-clips that really test your patience when you put it back together.
Old 08-03-2009, 07:48 PM   #10
hilandr452
hilandr452's Avatar
Careful when you pop that clip out, cup your hand around it or it could pop out and fly to the moon like mine did!!
Dan
Dan Smith
Old 08-03-2009, 08:00 PM   #11
brak
brak's Avatar
Grab a rag, rub it between the handle and the door panel, and it'll pop that clip off FOR FREE!!!
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 08-03-2009, 08:02 PM   #12
hilandr452
hilandr452's Avatar
The tool is like a buck and it will save you some headaches.
Dan Smith
Old 08-03-2009, 08:05 PM   #13
big mike71
big mike71's Avatar
I used a butter knife.
Old 08-03-2009, 08:23 PM   #14
hilandr452
hilandr452's Avatar
It looks like this.
Dan
Dan Smith
Old 08-04-2009, 01:53 AM   #15
CrazyIvan
Ah, thanks for all the advise. Will be confident taking it off now without breakin anything.
