quick, what parts would be useful off 77 chevy 1/2t??
Ok craigslist truck going to junk yard. What parts would should i nab off this beater before it goes to junkyard? Some recommendations would be great so I can call thia guy. thanks
Re: quick, what parts would be useful off 77 chevy 1/2t??
all the disc brake components ......maybe the whole front crossmember
DOH !!!!!!! |
Under Construction
front crossmember/saddle, brake booster/mc/line, power steering stuff, and the rear end are a few that come to mind.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Dave's not here, man
You could also nab the distributor if you're still using a points style
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
offered him 100 bucks, what do ya think. I want to convert to 5 lug, power steering , power brakes, I think that alone is a 100 bucks there dont you think? There is no drivetrain.
It's definitely worth $100 for those parts. You could probably make your money back scrapping it after you get the parts you need.
I am a Referee of life.
Any good body parts could also be sold/traded to a "Square Body guy".Maybe interior too.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
its all about the +6 inches
full guage cluster with or without a tach (not a dummy light set up)
tilt rear axle front suspention Any other 'nice' options Being you are in Nebraska, i doubt there's any sheet metal left. |
the body is straight and pretty rust free. what kind of mods could be done? like to convert to five lug. hopefully axles eill swap. what is the deal with the saddle? Is that for the newer motor mount swap?
the body is pretty straight with little rust. what conversions could I make? I have front disc on my 70 but would like to swap to 5 lug. Will the spindles w/ rotors swap? And hopefully rear axles would swap out. What is the deal with the front crossmember? Would that allow the newer motor mount swap? Any other ideas besides the power brakes and steering?
You could put new ball joints for the 77 in the arms you have now and run the 77 spindles to get 5 lug. That entire crossmember will swap also. I think you have to drill two holes, and the others will line up. I believe that will get you the new motor mounts you speak of. I think there is an easier way to get the newer style motor mounts without swapping crossmembers, though.
