Old 08-01-2009, 11:13 PM   #1
HOOPTY67
hood release cable broke today
so much for my plans to work on the engine. hoping to find away to get it open without breaking the new grille. damn.
and now i really wish i had installed hood pins instead.
-mike
HOOPTY67 is offline   Reply With Quote
Old 08-01-2009, 11:39 PM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: hood release cable broke today
ya know. you should talk to sillyoldman about what he uses with his hood. it is really trick! its like a lock and it dis arms the motor some how. but it is really cool and slick!
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 08-02-2009, 02:28 AM   #3
texasfunk
texasfunk's Avatar
on mine, i used a big screwdriver to pry the hood up a bit, high enough to get a block under it, then use a swivel 1/2 inch on an extension and took the bolts out for the latch, just be careful not to chip your paint,hope this helps
texasfunk is offline   Reply With Quote
Old 08-02-2009, 01:03 PM   #4
JohnC
JohnC's Avatar
A little off topic, but has anyone ever used a longer cable? That way you could hide it in the fender instead of running on the inner fender to the core support?
JohnC is offline   Reply With Quote
Old 08-02-2009, 01:22 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
mines tucked behind the front bumper
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-02-2009, 02:04 PM   #6
HOOPTY67
did the same thing. works good. problem solved.
-mike
Old 08-03-2009, 12:50 AM   #7
texasfunk
texasfunk's Avatar
good to hear
Old 08-15-2009, 08:02 PM   #8
3r!c84
Badass
3r!c84's Avatar
under the bumper?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
