Old 08-02-2009, 01:16 PM   #1
Martin64
Martin64's Avatar
6 Cylinder Engine I.D.?
I know this has to have been covered before somewhere here, but I can't find it. Can someone point me in the right direction?
Thanks!
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 08-02-2009, 01:33 PM   #2
Northern lights
Re: 6 Cylinder Engine I.D.?
There's some info in the "OMG what have I done" thread.
Northern lights is offline   Reply With Quote
Old 08-02-2009, 02:28 PM   #3
Martin64
Martin64's Avatar
It's blue and the motor mounts that are even across. So I'm reading that as it a 230?
Martin Gibson
USAF Retired
1964(-ish) C10
Old 08-02-2009, 07:52 PM   #4
ol Curt
Junior Member
ol Curt's Avatar
I somewhere have a link for i.d.ing between a 230 and 250 based on the numbers. If you'll look just behind the distributor, there is a flat pad that will have the id numbers stamped in it.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 08-02-2009, 08:00 PM   #5
ol Curt
Junior Member
ol Curt's Avatar
Here' some on this site under the casting numbers section
http://inliners.org/
Old 08-02-2009, 09:00 PM   #6
Martin64
Martin64's Avatar
That website shows my casting numbers (3850817) to be either/or 230-250 for year '64-76. The number next to the distributor is F0811TA
Martin Gibson
USAF Retired
1964(-ish) C10
Old 08-03-2009, 12:46 PM   #7
Martin64
Martin64's Avatar
I didn't see FO811TA on anyone's list. Does it sound familiar to anyone? Bueller?
Martin Gibson
USAF Retired
1964(-ish) C10
Old 08-03-2009, 05:08 PM   #8
ol Curt
Junior Member
ol Curt's Avatar
The distributor stamping pad tells what the compression ratio was, accessories the engine had and where the block was cast. I thought the compression ratio might help in determining between 230 or 250. It seems to me the TA designation was St. Louis. I'll keep looking for the info that breaks those numbers down. Did you look at the piston tops as is referred to in the other post? That would tell you for certain. It is always possible the original paint was covered over as well. The parts for the 230 and 250 are interchangable.
Old 08-03-2009, 07:56 PM   #9
Martin64
Martin64's Avatar
The motor is running...runs great! A little tempermental when starting it for the 1st time of the day, but warms up good and idles like a champ, no oil smoke. Of course I'm sure, not knowing the history, that could all change with the turn of the ignition key. The other casting numbers that are further back on the block toward the firewall do indicate that it's Chevy either/or 230/250 and nothing special fromwhat I've found on the other websites.
But, thanks for your help! I'm learning more details about this truck everyday.
Martin Gibson
USAF Retired
1964(-ish) C10
Old 08-04-2009, 05:53 AM   #10
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 6 Cylinder Engine I.D.?
CHEVROLET 6-CYLINDER 216, 235 AND 261 CYLINDER BLOCK CASTING NUMBERS
http://67-72chevytrucks.com/vboard/showthread.php?t=356268
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
Last edited by 1Bad62Pro/Street; 08-05-2009 at 10:20 AM. Reason: Stovebolt Casting Numbers
1Bad62Pro/Street is offline   Reply With Quote
Old 08-04-2009, 07:14 AM   #11
ol Curt
Junior Member
ol Curt's Avatar
Post Re: 6 Cylinder Engine I.D.?
With the intake hanging out he side like it does on these there is a little problem with vaporization of the fuel from the carb...especially when cold. There is a little flapper on the exhaust manifold that has a spring that expands contracts with heat allowing the flapper to open or close. Make sure it is not binding. If you can't find it, let me know and I'll post a pic of mine.
That's great that you got it running. Those things sing like a sewing machine! Looking to see the piston tops or pulling the pan and checking the crank numbers is probably the only way to id between the 250 or 230. They are identical except for the piston tops and the stroke is slightly longer on the 250.
Good luck!
Old 11-01-2009, 10:14 PM   #12
skelsey66
Engine ID:
230 CID 6 CYL
63-64 N, ND, NE
65 TA, TE ,TG
235 CID 6 CYL
60-62 J, JB, JC
250 CID 6 CYL
66 TA, TE, TF, SV, SW, SX
292 CID 6 CYL
63-64 PG, PK, PV, PL
65 UH, UT
66 UH, UU, UT, VQ, VR
283 CID V8
60-63 M, MA
64 M, MA, MX, MY
65 WA, WE,
66 WA, WE, WF, WH, WC
327 CID V8
66 YS, YR, YH, YC, YD
Location of engine number on 6 cyl is at the rear of the distributor, and on the v8 are immediately forward of the right hand cylinder head. Best of luck.
Found the table in LMCtruck catalog
skelsey66 is offline   Reply With Quote
Old 12-31-2012, 05:11 PM   #13
HawkFlight
Hi all ... New guy and my first post ...
I have a recently purchased a basket case 1962 Chevy C10 Stepside ... I found the engine number as F0409PC. When I look at the charts there is no PC. It is defiantly a straight 6. I was told it was a 290 or 292.
Any ideas ?
F = Flint ( Motor )
04= month = April
09 = day = 9th
PC = ???
Thanks in advance for the help.
Michael
snyderm@charter.net
HawkFlight is offline   Reply With Quote
Old 12-31-2012, 07:03 PM   #14
1Bad62Pro/Street
Arrow Re: 6 Cylinder Engine I.D.?
Any ideas ?
F = Flint ( Motor )
04= month = April
09 = day = 9th
PC = ???
Michael
snyderm@charter.net
Do you have the Casting Number off the block?
Chevy Six Cylinder Casting Numbers can usually be found just above the starter on the "passenger side" of the block.
http://67-72chevytrucks.com/vboard/s...d.php?t=356268
Casting # Make Year Displacement
1970 Chevrolet 64 - 67 292
2135412 GMC 46 - 54 248, 270
2192402 GMC (Military) 302
2193980 GMC 52 - 54 302
2324002 GMC 55 248
2324003 GMC 55 - 63 270
2324004 GMC 55 - 62 302
2404929 GMC 55 - 63 270
289890 Chevrolet 63 - 77 292
328518 Chevrolet 73 - 77 292
328572 Chevrolet 73 - 76 250
328575 Chevrolet / Buick / Oldsmobile / Pontiac 68 - 84 250
328576 Chevrolet / Buick / Pontiac 68 - 76 250
328578 Chevrolet 73 - 84 292
328880 Chevrolet 63 - 77 292
329990 Chevrolet 63 - 77 292
352194 Chevrolet 73 - 84 292
358825 Chevrolet 66 - 76 250
3629703 Chevrolet 50 - 52 235
364909 Chevrolet / Oldsmobile 75 - 79 292
3660439 Chevrolet 41 235
366855 Chevrolet / Buick / Oldsmobile / Pontiac 66 - 84 250
3692703 Chevrolet 50 - 52 235
3692708 Chevrolet 50 - 52 235
3692713 Chevrolet 50 - 52 235
3693374 Chevrolet 42 - 49 235
37001481 Chevrolet 53 - 55 235
3701946 Chevrolet 53 235
3703414 Chevrolet 54 - 56 261
37127 Chevrolet 73 - 76 250
3733340 Chevrolet 55 - 57 261
3733813 Chevrolet 58 261
3733946 Chevrolet 54 - 55 235
3733949 Chevrolet 53 - 55 235
3733950 Chevrolet 54 - 55 261
3737012 Chevrolet 55 - 57 261
3738307 Chevrolet 58 - 62 235
3738365 Chevrolet 60 - 62 261
3738476 Chevrolet 58 - 62 235
3738813 Chevrolet 55 - 63 261
3739365 Chevrolet 58 - 62 261
3739716 Chevrolet 58 - 62 235
3759365 Chevrolet 59 261
3764476 Chevrolet 58 - 62 235
3769716 Chevrolet 58 - 62 235
3769717 Chevrolet 59 - 62 261
3769925 Chevrolet 58 - 62 261
377127 Chevrolet / Oldsmobile / Pontiac 73 - 79 250
377129 Chevrolet 73 - 84 292
3773949 Chevrolet 54 235
3777178 Buick 68 - 76 250
3782856 Chevrolet 62 - 67 194
3782858 Chevrolet 62 - 67 194
378307 Chevrolet 60 - 62 235
3783949 Chevrolet 53 - 54 235
3788378 Chevrolet 62 - 74 292
3788406 Chevrolet 62 - 69 230
3788514 Chevrolet 62 - 70 153
3788813 Chevrolet 55 - 59 261
3789404 Chevrolet 63 - 76 292
3789412 Chevrolet 63 - 66 292
3789716 Chevrolet 63 - 72 292
3792852 GMC 62 - 66 194
3792858 Chevrolet 62 - 67 194
3821970 GMC 67 - 72 292
3833057 Chevrolet 62 - 70 194
3833067 Chevrolet 63 - 70 194
3833340 Chevrolet 55 - 57 261
383340 Chevrolet 55 - 57 261
3835253 Chevrolet 42 - 53 216
3835309 Chevrolet 42 - 49 235
3835335 Chevrolet 42 - 49 235
3835353 Chevrolet 48 - 52 216
3835363 Chevrolet 54 235
3835374 Chevrolet 42 - 49 235
3835491 Chevrolet 54 235
3835497 Chevrolet 42 - 53 216
3835527 Chevrolet 51 216
3835692 Chevrolet 50 - 52 235
3835794 Chevrolet 42 - 53 216
3835846 Chevrolet 53 235
3835849 Chevrolet 42 - 53 216
3835894 Chevrolet 53 216
3835911 Chevrolet 53 - 55 235
3835917 Chevrolet 54 - 55 235
3835946 Chevrolet 53 235
3835949 Chevrolet 54 235
3836012 Chevrolet 55 - 57 261
3836223 Chevrolet 55 - 57 235
3836233 Chevrolet 55 - 57 235
3836340 Chevrolet 55 - 57 261
3836386 Chevrolet 55 - 57 235
3837004 Chevrolet 55 - 57 235
3837012 Chevrolet 55 - 57 261
3843363 Chevrolet 53 - 55 235
3850817 Chevrolet 62 - 78 230, 250
3851656 Chevrolet 63 - 72 292
3851659 Chevrolet 63 - 76 292
3851859 Chevrolet 63 - 72 292
3854036 Chevrolet / Oldsmobile / Pontiac 62 - 76 230, 250
3855914 Chevrolet 63 - 66 292
3855987 Chevrolet 63 - 71 292
3855991 Chevrolet 63 - 70 230
3856233 Chevrolet 55 235
3858190 Chevrolet 54 - 55 235
386855 Chevrolet 74 - 77 250
3877178 Chevrolet / Buick / Oldsmobile / Pontiac / GMC 62 - 78 230, 250
3879875 Chevrolet 62 - 70 194
3886061 Chevrolet 63 - 66 292
3890011 Chevrolet / Buick / Oldsmobile / Pontiac 68 - 72 250
3890013 Chevrolet 68 - 72 250
3892858 Chevrolet 64 - 67 194
389770 Chevrolet 42 - 51 216
3897702 Chevrolet 42 - 53 216
3921770 Chevrolet 66 - 76 292
3921967 Chevrolet 64 - 69 230
3921968 Chevrolet / Oldsmobile 64 - 76 230, 250
3921970 Chevrolet 63 - 76 292
4001133 Chevrolet 76 - 80 292
6107326 GMC 39 - 52 228
6107328 GMC 53 - 54 248
828575 Chevrolet 72 - 77 250
8335794 Chevrolet 42 - 53 216
837751 Chevrolet 42 - 49 235
838101 Chevrolet 37 216
838710 Chevrolet 37 - 38 216
838941 Chevrolet 39 216
839132 Chevrolet 40 216
839400 Chevrolet 41 216
839751 Chevrolet 42 - 46 235
839770 Chevrolet 42 - 51 216
8397715 Chevrolet 42 - 49 235
839910 Chevrolet 42 - 51 216
839931 Chevrolet 42 - 49 235
8994256 Chevrolet 64 - 77 292
93403466 Chevrolet 75 - 83 250
93403467 Chevrolet 75 - 84 292
93406004 Chevrolet 75 - 84 292
9787437 Pontiac 66 - 67 230
9790043 Pontiac 68 - 69 250
9795066 Pontiac 68 - 69 250
9890043 Pontiac 68 - 69 50
http://www.adchevy.com/tools/casting...submit=Lookup#
http://www.inliners.org/casting/numbers.html
http://www.adchevy.com/info/article/...astingnumbers/
