Old 08-02-2009, 04:04 PM   #1
sjreno
My '87 TBI missing....
I've done some research about this problem, but couldnt find a solution. This seems to be a common problem with the 1st gen TBI, and Im hoping someone here can help. The truck feels like its missing at normal operating temp at idle. TIA.
sjreno is offline   Reply With Quote
Old 08-03-2009, 01:33 AM   #2
manitobamike
Re: My '87 TBI missing....
kinda sounds like what my 87 is doing , it hesitates then all of a sudden its like it was running on 6 cyl then the other two kick in , anyone have an idea what i should check? throttle body gasket?
manitobamike is offline   Reply With Quote
Old 08-03-2009, 01:52 AM   #3
texasfunk
texasfunk's Avatar
this was happening to my 90 once, couldnt figure it out, then, while spraying carb cleaner around the base to check for leaks, once it got to the front it stuttered, new gasket solvedit, might try this
texasfunk is offline   Reply With Quote
Old 08-03-2009, 07:25 AM   #4
Desert1957
Desert1957's Avatar
Hey Guys,
The most common problem like this is the "EGR" valve sticking, what happens is the valve will not seat after opening , causing some exhaust gas to enter the intake manifold at idle. It will make the engine computer think it running rich. so as the engine leans down it runs worse. Off idle is ok , maybe even a little hesitation. You can check it but taking it off and cleaning it with carb cleaner or trying to visually inspected it , which is harder.
If you really want to get into it you can make a block off plate / install a new gasket and see how it idles after. let me know what you find.....
Desert
Desert1957 is offline   Reply With Quote
Old 08-05-2009, 07:17 AM   #5
sjreno
Originally Posted by Desert1957 View Post
Hey Guys,
Desert
Thanks Desert, Im going to try that out.
