Old 01-09-2003, 01:52 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Improving suspension on my 30yr old truck...
How much will my suspension improve with new shocks....and what affordable shocks will be the best performing. I don't want a stiff ride....but I don't wanna bounce like I do now. Also how will replaceing the bushings from the pan hard bar and trailing arms improve my suspension????
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 01-09-2003, 11:33 PM   #2
CustomChevy
suspension rebuild
shocks will help alot. you also need to consider if any other parts have been replaced. items such as:
springs, cab bushings, a-arm bushings, leaf springs/bushings, etc.
CustomChevy is offline   Reply With Quote
Old 01-24-2003, 05:13 AM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
If I were you I would put in all new shocks, springs, and replace all the bushings. I put shocks and 2 inch front and 4 inch rear lowering springs in my 70 it rides a ton better but it squeaks horribly. just my .02
Oh I just picked up some monroe shocks from oriley's i think it cost me $80 for the set. I got my springs from early classic but payed about $60 too much from a local classic restoration shop here in okc. hope I helped some!
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 01-24-2003, 05:47 PM   #4
COBALT
COBALT's Avatar
Several months ago I was tempted to just drop in new shocks as well, until I looked at how bad my front/rear suspension was wearing.
I ended up rebuilding both with new bushings, new hardware, and new paint protection on all the parts. I reused my springs (and came up with a slick way to clean them), but most wouldn't think it was worth the time and effort to salvage them, but oh well...
You may find your suspension doesn't improve unless you take care of the entire package. Remember it's a system that works together to dampen force to the wheels in several directions. If just one part of that system isn't in good shape it will start to wear badly.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
