08-02-2009, 06:01 PM | #1 |
resident oilfield trash
Need Help C notching my truck
I just got my old coil springs off and there is a plate rivited to the frame. Is there any problem with just cutting the rivets off and doing away with the plate
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
08-02-2009, 06:18 PM | #2 |
Re: Need Help C notching my truck
Not sure what you mean. I had to grind off the rivets. I then used a template to cut out the notch. After, it was just a matter of drilling a few extra holes to bolt on the c-notch plate. I don't remember seeing any plate. I actually welding around the notch in after bolt just to help support it better (not sure if it was necessary).
[B]72 Cheyenne SWB |
08-02-2009, 06:36 PM | #3 |
This is the plate I am talking about. I had planned on just chopping it off but This side has my brake hose coming out of it. I know the bottom rivets have to go but does this plate go too or does it stay.
08-02-2009, 06:49 PM | #4 |
Don't mean to be insulting, but are you sure you're putting the notch in the right place?
08-02-2009, 06:58 PM | #5 |
What you mean it doesnt go under the cab.
08-02-2009, 07:05 PM | #6 |
Blaze-Air
NO, do not cut the rivets or the plate off. It stays. You will wind up having to trim the plate to fit the notch.
Click on my link in my sig. I'm sure you will see what needs doing. The notch will sit exactly where your old bump stop bracket is. It will be cut out. |
08-02-2009, 09:22 PM | #7 |
Thanks man NIce blazer. Now I just have to go bolt those plates back on
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada Last edited by jbristo67; 08-02-2009 at 09:22 PM. |
08-02-2009, 10:32 PM | #8 |
Yes...i believe that's correct. The plate stays on...teh outer portion of the plate the sticks outside the frame will need to be trimmed. After , the c notch should fit right over it.
