brighter than stock needed
just wondering if there is an option other than stock head, tail, and side marker lights out there? the stock ones in my '71 just dont cut it anymore at night.
'71 LWB c10-"WORK" in progress ![]() 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
its all about the +6 inches
Re: brighter than stock needed
First thing, unbolt the headlight ground wire from the core support and sand it to clean metal, do the same on the wire.
If not bright enough, then go to any parts store and get sylvania silver star seald beam lamps. They seem brighter than new cars. If that still isn't enough, then follow this link http://67-72chevytrucks.com/vboard/s...d.php?t=345919 in that list, there's a link in there for headlight relay upgrade. side markers, if you want more light output, then a 168 bulb will help, but the lenses are holding you back. a smooth style van marker lenses bolt right on. They can be found on mid 80's to mid 90's GM vans. |
Old member
I replaced the headlights with the tri bars along with the relay setup and it made a world of differance.
![]() I did these with the side markers. Bought off e-bay. They are diamond cut reflectors with smooth lenses.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
20' Daredevil (Ret)
![]() Join Date: May 2003
I'll second the relay mod, no matter what else you do.... and for more serious headlamp output, consider top brand-name E-codes, you won't regret it.
thanks for all the help guys, i think i will look into the relay upgrade first, see how that works and go from there
Honestly, the silver stars without relays, put out more than normal sealed beams, with relays.
The relay is a good idea though for other reasons, reduces the amps flowing through your 40 year old switch, high beam switch, and a mile of wires. |
#7 | |
20' Daredevil (Ret)
Edit: the following is from Daniel Sterns excellent web site... In many cases, the thin factory wires are inadequate even for the stock headlamp equipment. Headlamp bulb light output is severely compromised with decreased voltage. The drop in light output is not linear, it is exponential with the power 3.4. For example, let's consider a 9006 low beam bulb rated 1000 lumens at 12.8 Volts and plug in different voltages: 10.5V : 510 lumens 11.0V : 597 lumens 11.5V : 695 lumens 12.0V : 803 lumens 12.5V : 923 lumens 12.8V : 1000 lumens ←Rated output voltage 13.0V : 1054 lumens 13.5V : 1198 lumens 14.0V : 1356 lumens ←Rated life voltage 14.5V : 1528 lumens
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 08-04-2009 at 04:13 PM. |
ok i got the relays and started hooking everthing up before i left work, now am i doing something wrong or just confused? i was going by the headlight relay install thread, then i saw the tx firefighter pics of his relay install. I have two lg(high beam) wires on one relay, two lt(low beam) wires on the other. the ground and pos wires are not done yet but no worries there. my question is why in the pic was there three green wires to one relay and three tan wires to the other, was this for a different application or am i doing mine incorrectly?
the third one is the wire coming from the dimmer switch... the trigger wire. It should go to the 86 terminal
Old Skool Club
![]() Join Date: Jun 2001
In keeping with this thread, has anyone used the new LED headlights that I have seen on Speed Channel from time-to-time?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
i think when the link was posted for the leadlamps, everyone said the cost was insane.
