08-02-2009, 07:55 PM | #1 |
Rustoleum Spray on Bed liner
I have rust on my frame. Now I know most of us do!n
Problem is it sits for long periods of time outdoors. The undercarriage was originally sprayed with a rustproofing at the dealer and it has held up well considering. But over the last year or so it has begun to flake off. With all the rain we have had this year in the Northeast there is more surface rust starting than it had over the last couple of years. Sooo, I need a temporary fix to slow down the rust until I get ready to actually begin to tear it down and do it right. I am thinking of brushing the loose scale and using the Rustoleum Spray on Bed Liner product on the frame and undercarriage. Any one done this? Is it as good or better than Rubberized undercoating?
DIY body and paint work is cheap, making it look good... priceless -------------------------------------------- My Toys; ’26 Ford Model T ‘72 Triumph Spitfire 1500 '09 "The Briggs Flyer" Gettin' High. |
08-02-2009, 09:22 PM | #2 |
and a few others
Re: Rustoleum Spray on Bed liner
In my opinion, run from it. It's junk. I tried it once on an old beater truck I had inside the bed and I couldn't believe how thin it went on. Being it's called bed liner I expected it to be at least a LITTLE thicker than regular Rust Oleum, but I actually think it went on thinner.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
08-02-2009, 09:26 PM | #3 |
IMO, a rubberized undercoat would be more effective, as it has rust inhibiters in it.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
08-02-2009, 09:43 PM | #4 |
its all about the +6 inches
a light surface rust is nothing to be afraid of on the frame. If it sits... and is not driven in the salt and brine in the winter, then I'd leave it alone. You'll have more work into removing the bed liner stuff than you will removing rust. Besides, you need to remove the rust tto put on any bedliner anyways.
08-02-2009, 09:48 PM | #5 |
You could spray oil all over everything. That will keep the water and rsut away from it.
08-03-2009, 05:58 AM | #6 |
Covering therust is a bad thing.It`s better left exposed to the air.If you do anything,brush it down and coat with a spray lube or Permatex Rust Treatment.
When you go to use a self applied bedliner,in a proper application,give Dupli-Color spray on.I`ve used that and it`s good stuff.I`ve had it on a set of ladder racks for a couple years.It has a real nice texture that looks better than most professional coatings.
08-03-2009, 06:57 AM | #7 |
get a can of rust converter like eastwoods brand or por 15. you can paint on over the rust and it chemically converts it.
