Old 08-03-2009, 12:48 AM   #1
quickchevy
quickchevy's Avatar
Rear Brake ?
Have a 66.Changing to 5 lug.I know i need to use 71-72 drums.Do i need to use brake pads from the same years also?
quickchevy is offline   Reply With Quote
Old 08-12-2009, 11:20 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Rear Brake ?
I would assume you need the shoes that go with the drums, if I am understanding the question correctly. I'm not sure if they are the same from year to year, but my guess would be no.... are the backing plates the same?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 08-13-2009, 03:40 PM   #3
quickchevy
quickchevy's Avatar
Re: Rear Brake ?
The drums are the same size 11 x 2
Old 08-13-2009, 04:34 PM   #4
Bazooka
Keepin it old school
Bazooka's Avatar
Re: Rear Brake ?
You are doing a axle swap right?
If I remember correctly you just need to swap the drums. The other stock brake parts will work fine..
Bazooka is offline   Reply With Quote
Old 08-13-2009, 05:28 PM   #5
smashingchuck
Re: Rear Brake ?
If the drums are the same size I don't see why it wouldn't work just fine with the old hardware/shoes.
78 Build Thread
4Runner Build
Old 08-13-2009, 05:34 PM   #6
quickchevy
quickchevy's Avatar
Re: Rear Brake ?
Yes moser axles eaton posi unit.I looked up thru napa and same brake shoe number for 71 and 72 chevy truck.
Old 08-13-2009, 05:36 PM   #7
quickchevy
quickchevy's Avatar
Re: Rear Brake ?
Ok thanks.
