Old 08-03-2009, 04:32 AM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Question Help I ruined the OUTER GRILLE SHELL on my 72 How can I bring the shine back?
Over the weekend I decided to clean my outer GRILLE SHELL and I used Steel Wool to remove over spary from a privious paint job thinking it would clean it up a bit. I thought nothing of it so I went over most of the entire grille, till after I washed it I dried it up and thought the soap had stained it but I think I ruined my GRILLE it looks fogged,hazzed like soap scum. Can anyone help me with a salution to fixing it myself inexpensively polishing products? I can not afford $299.00- $399.00 plus shipping for a new or REPRO one. any suggestions would be great thanks Pablo.....
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 08-03-2009, 04:53 AM   #2
cdowns
cdowns's Avatar
Re: Help I ruined the OUTER GRILLE SHELL on my 72 How can I bring the shine back?
sounds like the original anodizing is still on the grill what you need to do is sand it down start with 200grit followed by 400 than 1000 after doing that and getting a nice even finish it's time to compound then polish it// labor intensive but cheap to do
Old 08-03-2009, 09:39 AM   #3
BP68
BP68's Avatar
Agreed, should keep sanding with proper grits and then start polishing.
I guess you could also paint it a silver color.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 08-03-2009, 09:46 AM   #4
sick69
sick69's Avatar
I'm not sure what the cost would be, but you might contact any local powder coating companies and see what the would charge to strip it, polish it and then clear it.
Or as was stated above break out the elbow grease and start sanding accordingly,,,,,,,
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 08-03-2009, 12:28 PM   #5
mclairmo
What about oven cleaner to get the anodizing off and then just polish? I've heard that works, never tried it though.
mclairmo is offline   Reply With Quote
Old 08-03-2009, 01:59 PM   #6
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
The only thing I can think of is use Simichrome polish and a whole lot of elbow grease.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 08-03-2009, 02:02 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-03-2009, 03:27 PM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
An easy way to get the original anodizing off is to use Easy-Off oven cleaner. Spray on, let soak for a little bit and when the anodizing starts coming off, wipe it down and wash it off.
After all of it is off, you can polish it up. Used to do this on motorcycle frames, to remove the anodizing off so you can polish up the frame.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-03-2009, 03:36 PM   #9
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Pablo I might go with getting a quote from a professional polishers first.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 08-04-2009, 02:22 AM   #10
petey-pablo
"THE GREEN GOBLIN"
Thanks guys I will try Easy-Off oven cleaner Spray to get the original anodizing off at lease to make it look nicer, Then get a quote from the pros this week . If Not I will be driveing my truck with out it untill I polish it up my self....
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 08-04-2009, 03:10 AM   #11
leddzepp
Moderator
leddzepp's Avatar
x 2. I did this on one of my trucks as well. After easy off, use sandpaper method as cdowns described. i used a dremel tool and a lot of polishing pads to polish/buff it out.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
