Red Headed Step Child
Aftermarket fuel filler in the bed floor
Those that have done this mod.
How did you keep the filler above the filler opening for the gas tank?? I've been searching for hours. I saw mudder's thread but his truck has a body lift. I'm trying to figure out how I can make the 90° turn under the bed floor and get to the tank opening and not have the fuel filler line be going "uphill" All of the 1-1/2" pipe i've found doesn't make a tight 90 turn. It's got a bigger radius. What can I use? Here's a picture of the tank kind of mocked in the frame rail. You can see the filler on the left side just below the two vent openings ![]()
"Dinner, the perfect break between work and drunk" -Homer Simpson |
Re: Aftermarket fuel filler in the bed floor
morning bump since you guys are early birds
Under Construction
I have seen ppl have the pipe custom bent at a muffler/fab shop. ?You should be able to search for blazer tank etc, and get a plethora of info.
Heath
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
