Old 08-03-2009, 07:19 PM   #1
mtm_seven
Loading.....
mtm_seven's Avatar
How do I make the rear leafs softer?
Hey gang,
I have a little 4x4 project that started as a dually and now has single rears and no bed - as you can imagine, it beats you to death offroad with the stiff rear springs and no weight. (running 15 and 12 psi in the tires)
Question, how can I keep the same ride height but make the rear springs softer? - What part of the packs should I remove and how big of a block should I plan for? Or is there another option like swapping some front leaves to the rear? I have a plasma and a mig; not afraid to use them
Uglee huh?
-M7
'69 SWB GMC 5.7 EFI
‘69 C/10 SWB patina survivor
‘71 GMC K20
'72 K5 1-ton gear 468BB
‘86 K30 GMC High Sierra C&C Single Cab
'96 SWB Single Cab 5.7
‘99 SWB Z71 Single Cab
'00 SWB Single Cab 5.3
'01 K2500 Yukon Safari 6.0
‘06 2500HD Single Cab C&C Duramax 4x4
'08 1500 crew
'11 2500HD Single Cab Duramax 4x4
mtm_seven is offline   Reply With Quote
Old 08-03-2009, 08:20 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: How do I make the rear leafs softer?
Put the bed back on it and load it down with about 1,500 lbs of watermellons!
Actually, the best method I found to make these ride better is do a rear spring shackle flip. It is amazing the ride difference with the flip which I was not expecting or looking for, the smoother ride was a secondary bonus.
ORD has one of the better shackle flip kits IMHO. http://www.offroaddesign.com/catalog/shacklekit.htm
After adding 52" rear springs and longer shackles. Really rides nice now, flexy too.
DirtyLarry is offline   Reply With Quote
Old 08-05-2009, 11:56 PM   #3
mtm_seven
Loading.....
mtm_seven's Avatar
Hmmm, good point - I could do this and remove leafs as needed to get back down to size:
http://www.coloradok5.com/shackleflip.shtml
Want to remain as low as possible (height and $$-wise) - building it to teach my niece and nephew how to drive standard and laugh at them hitting trees.
-M7
'69 SWB GMC 5.7 EFI
‘71 GMC K20
'08 1500 crew
Old 06-27-2016, 11:47 PM   #4
lyrikz
PITbut
lyrikz's Avatar
I know this is an old post but I'm looking for flex and a softer ride also. I mostly do sand which is higher speeds and bumpy. I'd like more travel so the shocks can take care of the rest. Would you recommend d this for the front and rear?
1971 chevy blazer 1/2 ton. Has a basic lift now. Couple of inches. 35 inch tires.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 06-28-2016, 08:37 AM   #5
andrewmp6
That is for the rear and it would soften the ride some,The off road guys do a 52 inch spring swap in the front which do flex more.Keep in minding doing both will give you 4 to 5 inches lift if i remember right.
andrewmp6 is offline   Reply With Quote
