Old 08-03-2009, 08:39 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
what could it be
ok so i unhooked the speedometer cable from my transfer case hooked it up to a drill and it all worked fine but when i hook the cable back up to the transfer case it doesn't work at all
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 08-03-2009, 08:49 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: what could it be
did you pull put the speedo gear in the tcase and look at it?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-03-2009, 08:57 PM   #3
pokethesmot
nope....how hard would that be to do
Old 08-03-2009, 09:04 PM   #4
3r!c84
Badass
3r!c84's Avatar
get some needle nose pliers and pull it out
-00 Saturn 5spd
1/4:13:90
Old 08-03-2009, 09:10 PM   #5
pokethesmot
so its that dang easy...about how much would the part be
Old 08-03-2009, 09:13 PM   #6
3r!c84
Badass
3r!c84's Avatar
few dollars
im not 100% sure on the tcase but that should be the same as for the trany tail shaft.
they are different colors for different number of ratios
-00 Saturn 5spd
1/4:13:90
Old 08-03-2009, 09:22 PM   #7
willett
Another Day, Another Dollar
willett's Avatar
classic parts has spedo cable gears listed for under $10
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 08-03-2009, 09:23 PM   #8
pokethesmot
well i pulled out a black piece of plastic its like a plastic dowel with a spiral cut into it...is this it and how can i tell if this thing is broke...thanks so much for the help by the way
Old 08-03-2009, 09:26 PM   #9
willett
willett's Avatar
does it look mangled? does it move the spedo cable if you shove it in there and turn it?
Old 08-03-2009, 09:27 PM   #10
pokethesmot
thats a good idea ima go check that but the insides do kinda look mangled
Old 08-03-2009, 09:45 PM   #11
3r!c84
Badass
3r!c84's Avatar
yea its probly striped out and its not sping the cable
-00 Saturn 5spd
1/4:13:90
Old 08-03-2009, 10:18 PM   #12
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
If it looks like a dowel then something is broke. It should have a gear on the end of it. The color of it is how you tell which gear you will need (I think).
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 08-03-2009, 10:45 PM   #13
pokethesmot
does any one have a pic of one cuz i see no gear on the end of mine
Old 08-03-2009, 10:53 PM   #14
3r!c84
Badass
3r!c84's Avatar
google it
-00 Saturn 5spd
1/4:13:90
Old 08-03-2009, 10:58 PM   #15
pokethesmot
yeah my junk is defiantly broken...how am i suppose to get the rest of the gear out of there?
Old 08-03-2009, 11:16 PM   #16
3r!c84
Badass
3r!c84's Avatar
get a needle and pock at it.try to get it out
-00 Saturn 5spd
1/4:13:90
Old 08-04-2009, 01:18 PM   #17
pokethesmot
damn i called up to advance and they didnt even know what i was talkin about
Old 08-04-2009, 02:52 PM   #18
3r!c84
Badass
3r!c84's Avatar
ahaha good help is hard to find
-00 Saturn 5spd
1/4:13:90
Old 08-04-2009, 03:20 PM   #19
sailed2japan
Jonny
sailed2japan's Avatar
Whoever you talked to really shouldn't be working at a parts store.
The color of the gear denotes how many teeth it has. Different # for different ratios, you can also change the gear to adjust for tire size changes. I know there is a calculator for this somewhere, unfortunately, that's a link I forgot to save....
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 08-04-2009, 04:21 PM   #20
pokethesmot
well i called advance and i told them i need a speedometer gear and told him what it looked like and he said"uuuuuuh we got a speedometer cable" lol does any one know maby the part number for a black speedometer gear from a th350 i think 40teeth
Old 08-04-2009, 06:15 PM   #21
nlped
nlped's Avatar
Here is a link to the place I got my new speedo gear from when I went from a 2.73 to a 3.42. Got the part in like 3 days. I bought it from them via Ebay and it cost $9 shipped. Hope this helps.
Cheers,
Ed
http://www.transmissioncenter.net/sp...FQE0xgodER69XQ
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-04-2009, 07:02 PM   #22
Albatrossian
Georgia Boy
Albatrossian's Avatar
poke, call Corthern-Varnadore and tell them you need a black speedo gear. They'll know what you're talking about. It's $10 at the most.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 08-04-2009, 09:07 PM   #23
pokethesmot
thanks everyone and my biggest thing is im not gunna be able to order it off the internet and whats "Corthern-Varnadore"?
Old 08-04-2009, 09:31 PM   #24
Albatrossian
Georgia Boy
It's the GM dealer in Hazelhurst.
Old 08-04-2009, 09:45 PM   #25
pokethesmot
oh, thank you man i owe you one
