Old 08-03-2009, 09:48 PM   #1
hammerdog57
hammerdog57's Avatar
Radiator support interchange?
Will a 57 6400 radiator support and radiator fit a 55 3100? What about the hood? Found a real clean one for parts but dont want to buy it if these parts wont interchange.
hammerdog57 is offline   Reply With Quote
Old 08-03-2009, 10:30 PM   #2
GRIMSS
GRIMSS's Avatar
Re: Radiator support interchange?
I bought a 2 ton 57 for parts. I think the only parts that wont interchange are the grill, upper and lower grill supports, and fenders.
Inner fenders, hood, cab, and I think radiator support are the same.
See if anyone else can add to this.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 08-04-2009, 01:23 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
The radiator for the big truck is taller and thicker. It will clear the hood, but requires the flange on the splash pan to be moved forward for clearance. Also, the brace across the front at the top of the radiator needs cut. On my friend's truck the brace was cut out completely. It could be trimmed, leaving just the lowest part of the brace.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-04-2009, 02:16 PM   #4
OrrieG
OrrieG's Avatar
I put a big truck radiator in mine, did not check the height to original, looks like I may be doing some trimming.....thanks for the heads up
OrrieG is offline   Reply With Quote
Old 08-04-2009, 07:40 PM   #5
hammerdog57
Anyone know for sure about the radiator support and inner fenders? Im thinking that they will not work.
Old 08-08-2009, 10:21 PM   #6
OrrieG
OrrieG's Avatar
I stacked them up side by side and the 59 1/2 ton is the same height as the 56 1-1/2 ton. The big truck radiator is 1" thicker and about 1.5 wide on both side. From a trial fit I know it mounts in the 1/2 ton radiator support using the stock holes. Maybe the taller one came from COE or even bigger truck??
