Old 08-04-2009, 06:26 AM   #1
MTtruck
MTtruck's Avatar
Red face Worth fixing???
It appears i have a leak around the tranny (muncie). This is a daily driver for me and I only get a small drip or two a day but it still bugs me. I t seems to be leaking around the top of the case maybe and running down the side. Thought I would ask and see what y'all would do bout it if anything.
Paul"Give old trucks a second chance"
MTtruck is offline   Reply With Quote
Old 08-04-2009, 09:05 AM   #2
BluTrukker
BOHICA
BluTrukker's Avatar
Re: Worth fixing???
I would fix it if it bothers you. Pulling a muncie is pretty easy, so new seals would be a weekend project. If it doesn't bother you, keep the oil level up and drive it. If you have to add a little from time to time at least you keep fresh oil in it
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 08-04-2009, 11:40 AM   #3
mclairmo
Re: Worth fixing???
Depends on the truck and you. If it is a show piece, fix it. If not, and you can stand it, leave it. However, it it will keep you up at night, fix it. I've been chasing a trans leak on my Camaro show car for years now and have finally pinpointed it to the cooler lines after replacing the pan, dipstick tube, and vacuum modulator. These small leaks can be tough to locate.
mclairmo is offline   Reply With Quote
Old 08-04-2009, 01:07 PM   #4
big_al_71
big_al_71's Avatar
Re: Worth fixing???
Those small tiny leaks are a pain in the rear to determine where they are coming from, me being the perfectionist I am will be getting it fixed right of way. I have gone thru some crap sometimes worrying about insignificant things in the bucket but I want it as good as possible...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-04-2009, 01:30 PM   #5
vectorit
What?
vectorit's Avatar
Re: Worth fixing???
Like the others said, it depends on how much it bugs you. But if it gets so bad to where you have to keep checking the oild level, then personally I would fix it.
My rear axle and transfer case leak quite a bit during the hot weather, and it seems like a never ending battle for me to fix em since it does bug me. Plus I hate the smell of hypoid oil!
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
