I need a plan before all these ideas spin out of control
I have one complete running truck.... 68 50th lwb...
And ontop of that, I have a whole other 71 cab, and a 67 parts truck/frame that I plan to shorten, plus 2 other rears, trailing arms, etc.. What do I do? Do I just start building a new truck, and not bother swapping frames? My initial plan was to cut down the 67 frame, and swap everything off the 68 onto that frame... basically, just swap frames, and turn my 68 into a short bed.. BUT.... the cab on the 68 is in need of repairs before it's worth swapping over to something else, and I don't want to be without a running / driving truck. And to top it all off, I was just quoted $1300 for a complete 6.0 lq4/9.... The wheels started turning, and I thought about shortening the '67 frame, buying a 6.0, and building a truck from the bottom up using the 71 cab (that also needs repaired...). I'd probably go with a 73-87 front suspension, or use the 67 suspension that I have on my parts unit.... I'll need an entire front clip for either project. Now, the idea is all fine and dandy, but I want to keep my 50th. What I almost need to do is build a "junk" truck (using the 71 cab, 67 frame and drivetrain, wooden flat bed (on the cheap...) Then just tear down my 68 50th, and build that one back up nice from start to finish. Maybe I should ask my wife what I should do. Ok, maybe that's not such a good idea. I guess I could also build the 71 shortbed, and drive that while I re-do the 68 50th, but I don't have the funds, time, or resources to do 2 complete builds. What would you do? |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: I need a plan before all these ideas spin out of control
I say stick to whatever your original plan was and see it through the end. Otherwise you will wind up with a couple of projects that don't get finnished. Ask me how I know....
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
I guess the original plan was to just swap everything over to the shortened frame, buy new bedsides, and make some emergency repairs to the 68 cab while it's off. The 68 cab isn't that bad, but I hated to take the time to swap it over to a different frame without trying to make it better.
I would not touch the 68 other than to maintain and repair it. Youu need to keep it running at all times or you will lose momentum and become disullusioned. Do whatever you want with the other parts you have, like building another truck, but keep the 68 running at all times.
#5 | |
I'll still have the dilema of what to do with the 68 when the "new" truck is done, but swapping my fair/poor 68 cab and front clip onto a different frame just so I can have a short bed doesn't make sense. Last edited by Jim_PA; 08-06-2009 at 12:09 AM. |
I think that is best so as to avoid the trap of having a lot of projects, none of which run at all. I have my 67 Camaro, which runs great and so, it's no big deal if my truck is apart for several years. However, if they both were down, I would be depressed.
